squeal at idle
Old Nov 7, 2012 | 03:59 PM
zukijames's Avatar
Default squeal at idle
when my rpms are below 900 i often have a squealing noise.. if i give it a little gas it goes away..
doesn't happen tell the vehicle has been running for a little bit.
i've had it idle for 1.5 hours and never do it .. next morning drive a little ways let of the gas and its doing it
i think it might be something to do with the abs?
Old Nov 7, 2012 | 04:53 PM
I would be more inclined to suspect worn glazed cracked serpantine belt, or something it turns. When it is squealing, take a boomhandle or long screw driver, to keep your dreadlocks out of the belt, and put handle to your ear and press other end against suspct items, you'll narrow down the noise. With belt off you can turn individual items and check for roughness.
Old Nov 7, 2012 | 05:52 PM
Rovin4life's Avatar
Is the belt on correctly as well?
Old Nov 7, 2012 | 07:02 PM
fishEH's Avatar
Check the tensioner pulley too, those are known for grenading at the worst possible times.
Old Nov 7, 2012 | 10:56 PM
LRchick's Avatar
Well, the problem I had was similar. At low RPM, between idle and roughly 1100 I was getting a whiney squill. As soon as the RPM'S jumped above that it instantly disappeared. Belt was good. I was able to centralize the noise to the housing behind the water pump pulley. I took the belt off and the pulley made the noise when turned by hand. I replaced the water pump and haven't had a problem since.
Old Nov 7, 2012 | 11:14 PM
Also put the Mark I eyeball on the belt from the side, to check for any wobble, such as the water pump like LRchick mentioned. As they fail, eventually they wobble more and more, and even start leaking at the shaft. Inside, the impeller begins to eat aluminum. Anything turned by the belt can turn aginst you if the Rover gods are not happy with you.
Old Nov 9, 2012 | 03:46 AM
tooltech's Avatar
I had the same squealing noise too. My fix was the water pump bearing/seal. So I replaced the whole pump... squeal is now gone!
Old Nov 14, 2012 | 05:09 AM
zukijames's Avatar
thanks for all the info guys! i went to moab for a few days and it only did it the first day.. went out rock crawling yesterday and it did it once.
i'll use the info you guys shared to start diagnosing thanks again everyone!
Old Nov 14, 2012 | 01:52 PM
Jake1996D1's Avatar
If you can get it to do it at home use a can of wd40 to spray the bearings on they pulleys. Usually you'll fix the issue. If that doesnt do it remove the belt and try spinning all of them by hand. If any are tough to spin - except the crankshaft pulley you found the issue.
Old Nov 14, 2012 | 01:58 PM
zukijames's Avatar
thanks jake i'll go wd40 all of them just for fun.
tried to work on my girlfriends to get it ready for the new intake and propane..
got the radiator out and gave up .
