started swivel rebuild
Old Oct 21, 2011 | 06:22 PM
tweakrover's Avatar
Default started swivel rebuild
Check out what I found, its been riding fine that ball bearing was in the bottom of the swivel,
Old Oct 21, 2011 | 07:07 PM
psykokid's Avatar
Where's the missing chunk of the race?
Old Oct 21, 2011 | 07:24 PM
Danny Lee 97 Disco's Avatar
Pics are a bit blurry.
Old Oct 21, 2011 | 07:37 PM
tweakrover's Avatar
Yea sorry the flash really screws with the pic, the broken race pieces fell out of the swivel after I got it off, they must have been in the bottom sitting in the oil. The crazy thing is the cv functions fine without the one bearing, obviously im not gonna put it back in cause its defiantly weakened, but it didn't click or nothing.
Old Oct 21, 2011 | 07:43 PM
tweakrover's Avatar
Has anyone changed the top swivel pin from an abs top pin to a nonabs one, just wondering cause if the top pin or bushing it sits in is worn, its cheaper to buy a non abs pin and bearing from a range rover.
Old Oct 21, 2011 | 08:03 PM
I would imagine that the non ABS will work just fine, you just wont have ABS.
Old Oct 24, 2011 | 10:28 AM
Paul Grant's Avatar
I would check on that cross compatibility of upper swivel pins. If you're talking about a less than $40 difference, I'd rather go with the correct pin. The kit AB has includes the bearing and washers for $59.99 where the non-ABS unit at $19.99 does not.
Old Oct 24, 2011 | 11:21 AM
tweakrover's Avatar
Well I won't need the pins so I'm gonna just stick with the bearings, I'm gonna order everything tonight. I remember someone fixing some pitting on the swivel ***** with jb weld then painting them, how has it held up.
Old Oct 24, 2011 | 11:55 AM
calebbo's Avatar
What all do you need for the rebuild?
Swivel Pin, Bearing, and shims?
(Which bearing)
Old Oct 24, 2011 | 04:22 PM
tweakrover's Avatar
Just ordered it all today, seals and swivel bearings.
hazletbassist89
Mar 25, 2011 02:38 PM
kenk
Jun 9, 2010 11:10 AM
kenk
Feb 9, 2010 11:43 AM
DrCox
Aug 3, 2009 08:47 PM
reflextuning
Jul 18, 2008 12:03 PM
