My 97 wont start .
Old Oct 20, 2011 | 12:34 AM
gunrunner's Avatar
Default My 97 wont start .
Ages ago my rev counter has been all over the place then had the usual starting probs , had it checked and alternater was fine so a new battery fixed it but never the rev counter as it has always been playing up . 3 months later now it wont start but cranks over - need help .
Old Oct 20, 2011 | 01:08 AM
adigerol77's Avatar
Need more info please...have you checked the fuel pressure...any alarm issues...what have you fixed within the last year...miles...fuel filter etc. So your tach is out of whack, ask Danny Lee, that's usually an alt prob but shouldn't lead to a non-start issue. This sounds like a fuel delivery issue to me.
Old Oct 20, 2011 | 01:24 AM
gunrunner's Avatar
As for the tach , it usually is dead then starts working after 5 mins but it is always all over the place . Sounds to me not getting any diesel .
Only had it bout 3 months , will check the fuel filter .
Old Oct 20, 2011 | 04:09 AM
gununner,
with all our Jedi powers, we just can't quite make out the shape of the pile of abused metal you call an engine.... you'll get a lot more help, and sometimes spot on, if you tell us what you are working with. '97 Yugo? '97 Corvair? '97 Mite-neva-krank?
Meanwhile, use your computer skills and download the factory shop manuals, called the RAVE, at the link below.
A sample page is attached, for the tachometer, which is same wiring for the most part diesel or gas. The alternator has wires on the back that attach by bolts, and a small one that has a push on clip. That's the one that takes the signal to the tach. If connector is dirty, or if wire is pinched, skinned up, grounded, gnawed by rats, anywhere between tach and alternator, that could be a problem. Or could just be bad tach. Usually when alternator fails, tach goes to zero. But if you have on again / off again brushes in the alternator, might do as you have observed. If you can read volts on battery when tach is dead or erratic, and volts are between 13.8 and 14.4, it is not the alternator.
File Type: pdf
Old Oct 20, 2011 | 04:50 AM
Long Haul's Avatar
Check the fuel filter, glow plugs and glow plug relay for th non start issue. As far as the tach issue i think Savannah has that pretty mutch covered
Old Oct 20, 2011 | 05:35 AM
could be some fuses, may not have needed glow plugs until it got chilly...
pages attached
File Type: pdf
Old Oct 25, 2011 | 12:15 AM
gunrunner's Avatar
Managed to roll it back and it started but 3 days later it has happened again .
Old Oct 25, 2011 | 12:20 AM
gunrunner's Avatar
Have got a fuel filter on order , now thinking about it , it happened when it was nearly empty and i put 88 litres of diesel in her ..
disconic
Jun 4, 2016 02:57 AM
gustav23
Dec 15, 2011 01:12 PM
armyeng
Mar 8, 2011 05:58 PM
jonsimon
Jan 29, 2007 01:55 PM
