Steering " Dead Spots" and a leak - 96 Discovery
Old Jan 9, 2019 | 01:15 PM
mware18's Avatar
Default Steering " Dead Spots" and a leak - 96 Discovery
A couple of months ago I replaced all the seals on my steering box and replaced the PS hoses. All was great until a few days ago. I feel a couple of "dead spots" like the power steering is not working. It doesn't happen every time I drive but does happen often. It may lasts for a few seconds.
The odd thing with the dead spots is that there is always drops of steering fluid shortly thereafter. It is coming from one the 4 bolts on top of the gear box. Specifically, the one closest to the front. All are tight but I guess there is a gasket I didn't replace!
Any thoughts? I do not want to spend my Saturday removing the steering box again.
Thanks for the help.
Old Jan 9, 2019 | 10:04 PM
XCELLER8's Avatar
as far as the gasket goes, there's a square-cut o-ring under the cap on the top, been there...........
.....if the leak was bad enough you could get a "momentary " issue I suppose, but more likely the box has some wear internally
Old Jan 10, 2019 | 07:31 AM
WaltNYC's Avatar
Those boxes are notoriously difficult to rebuild successfully.
Old Jan 10, 2019 | 08:32 AM
mware18's Avatar
thanks guys.... is that gasket replaceable without removing the box? looks tight but i guess it would be better than removing the whole thing.
Old Jan 10, 2019 | 08:22 PM
XCELLER8's Avatar
yes.....four bolts on the top. and the adjustment screw/ lock nut
lestro
Jun 21, 2021 05:13 AM
amfoto1
Jan 10, 2015 04:54 PM
texci77
Jun 6, 2012 01:24 PM
Eaglerover22
Mar 28, 2012 05:04 PM
chrisusvi
Jan 29, 2009 05:54 PM
