Stiff Gas pedal...
Old Mar 18, 2012 | 09:22 PM
Tim08's Avatar
Default Stiff Gas pedal...
The gas pedal in my 1999 Land Rover is hard to press when I first take off in my truck. It is smooth after my truck takes off, but it acts as if it is stuck when I first take off and it makes for a jack rabbit take off. Does anyone know what might cause this and how it can be corrected?
Old Mar 18, 2012 | 09:47 PM
jafir's Avatar
Could be a dirty throttle body.
Old Mar 19, 2012 | 09:12 AM
XCELLER8's Avatar
try unhooking the cable at the throttle-body and see if the cable moves freely....that should narrow it down some
Old Mar 19, 2012 | 08:35 PM
Tim08's Avatar
Guys, I am not sure what the throttle-body is or where it is located... I am new to this mechanic stuff.
Old Mar 19, 2012 | 09:44 PM
https://landroverforums.com/forum/di...leaning-19664/
DI Tech Section
Old Mar 19, 2012 | 10:00 PM
adigerol77's Avatar
Sorry I know off topic but when I read the thread title, I swear I thought your disco had swallowed a Viagra.
Old Mar 20, 2012 | 05:38 AM
Tim08's Avatar
You guys are great! Thanks for the info. This helps a lot!!!
Old Mar 22, 2012 | 02:40 PM
leadfoot's Avatar
Tim, did you solve your problem? Did you find the cable as suggested above? I see you are new to this, so let us know if you need a picture of what to look for.
Old Mar 22, 2012 | 08:24 PM
Tim08's Avatar
I found the throttle body and I cleaned the throttle body, but it did not help. I notice the little lever hooked to the linkage outside of the intake seems to stick. Is there suppose to be some rubber seat for this to rest on when the car is not being accelerated?
Old Mar 22, 2012 | 09:02 PM
You need to lube the throttle cable/springs/linkage with silicone spray.
With the engine off lube it all up good, open and close the throttle by hand, lube some more.
Report back.
