Stiff Steering
Old Apr 3, 2012 | 08:54 AM
jeff spahn's Avatar
Unhappy Stiff Steering
I just replaced my steering box for the second time (a whole different thread but suffice to say a junk rebuilt part from Rock Auto was the cause).
My steering wheel, WITHOUT THE STEERING BOX ATTACHED, is not as free to turn as it had been. I had taken the wheel off several times (also part of the original saga). Is there a way I could have "jammed" or preloaded a bearing on the steering shaft itself that has caused it to be a bit stiffer than it was before the whole process began?
Would a tap from the end of the shaft in the engine compartment with a plastic mallet or a deadblow hammer be a bad idea?
Thoughts, recommendations?
Old Apr 3, 2012 | 09:03 AM
Jake1996D1's Avatar
Sounds like you ruined the clockspring... This is why you do NOT want to turn the steering wheel without the box attached...
Whenever you take your steering shaft off always tie down your steering wheel so it does not spin.
Old Apr 3, 2012 | 09:48 AM
jeff spahn's Avatar
Yeah, know that now. No clicking or anything, all functions that worked before, work now. So, do I need to replace it or just leave it?
Old Apr 3, 2012 | 09:52 AM
Jake1996D1's Avatar
Umm well, if I were you? I would
Do you HAVE to? No
Old Apr 3, 2012 | 09:58 AM
jeff spahn's Avatar
Do you HAVE to? No
For $35, I might as well.
Old Apr 3, 2012 | 10:25 AM
Jake1996D1's Avatar
Yup! I'd hate to put it all back together and not do it to find our your truck drive like crap
JoMar
Jun 26, 2013 06:20 PM
squid
Freelander
Mar 13, 2009 06:45 AM
viper205
Jun 23, 2008 08:14 AM
dillhole
May 31, 2008 06:40 AM
Catsailor
Oct 9, 2007 05:16 AM
