Still can't get rid of P0340..where to check ECU connection?
Old Aug 20, 2020 | 10:09 AM
jekylczar's Avatar
Default Still can't get rid of P0340..where to check ECU connection?
My P0340 woes continue.
Replaced the camshaft sensor
Replaced the crankshaft sensor
Replaced crankshaft sensor wiring
Still have P0340 popping up. I read in another thread that sometimes water can damage the connection at the ECU. I can't find a pic of where to check for this.
Any help certainly appreciated...I'm pulling my hair out!
Old Aug 20, 2020 | 10:32 AM
Best4x4's Avatar
Well if you think you might have ECU issues I'd remove the ECU and remove the covers and inspect for any sort of corrosion. Also make sure the 3 main plugs aren't corroded. When I got my 97 XD which lived most of it's life up in Iowa it refused to run right. I also couldn't connect an OBD2 scantool to it. Finally removed the ECU, and found it completely corroded!!!!! Found a replacement and it ran like a new truck!
Old Sep 15, 2020 | 07:01 PM
Best4x4's Avatar
You really need to remove the ECU under the hood & open it up and check for water damage to the PCB or connectors.
PanicInTheDisco
Apr 21, 2019 04:00 PM
Hanomag
Mar 7, 2015 07:02 AM
morbengan
Jun 16, 2014 05:57 AM
Extinct
Apr 24, 2013 07:21 PM
JRdisco1
Aug 25, 2005 03:07 PM
