Still having heater problems
Ok some background info first. Replaced radiator, waterpump, head gaskets,
coolant tank and cap, thermostat, heater control valve and hoses, flushed heater core bi directionally. Heater works then doesnt. Sometimes works at idle sometimes moving down the hwy. Just kind of comes and goes with no rime or reason. Checked coolant level bled coolant system as described in threads. Temp gauge stays right in the middle. Checked belt routing as per diagram. The only odd thing I have noticed is the PO pinned the fan clutch so that it is locked all the time and the radiator feels cool to the touch never hot.
Any Suggestions?
Any Suggestions?
T-stat opens, coolant cools to much, no heat.
T-stat closes, coolant heats back up, heat.
