Still having heater problems
Old Dec 19, 2010 | 01:19 PM
DiscoDad's Avatar
Default Still having heater problems
Ok some background info first. Replaced radiator, waterpump, head gaskets,
coolant tank and cap, thermostat, heater control valve and hoses, flushed heater core bi directionally. Heater works then doesnt. Sometimes works at idle sometimes moving down the hwy. Just kind of comes and goes with no rime or reason. Checked coolant level bled coolant system as described in threads. Temp gauge stays right in the middle. Checked belt routing as per diagram. The only odd thing I have noticed is the PO pinned the fan clutch so that it is locked all the time and the radiator feels cool to the touch never hot.
Any Suggestions?
Old Dec 19, 2010 | 02:03 PM
Replace the fan clutch, if it is running all the time the truck is running to cold.
Check the tech section for a more affordable replacement.
Old Dec 19, 2010 | 06:11 PM
okdiscoguy's Avatar
I would say the control valve or air in the cooling system. If the fan was cooling too much, the thermostat should just close and heat things up
Old Dec 19, 2010 | 06:51 PM
Thus the heat then no heat situation.
T-stat opens, coolant cools to much, no heat.
T-stat closes, coolant heats back up, heat.
TRIARII
Dec 29, 2012 12:48 PM
00rove
Mar 6, 2012 07:10 AM
tex599
Jun 22, 2009 10:03 AM
mestupstud
Dec 12, 2007 09:57 AM
russ00001
May 9, 2006 08:53 PM
