Major High Mileage Service for D1's
Old Dec 20, 2010 | 10:28 AM
Default Major High Mileage Service for D1's
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Factory air filter
6 Qts. of engine oil
2 feet of 3/16th vacuum tube
2 feet of 5/16th vacuum tube
6 Qts. Of Vavoline’s high mileage Dextron 3 ATF
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of Vavoline’s DOT 4 Brake fluid
4 Qts of ATF fluid for the power steering
2 Gallons of Peak or any green or yellow coolant, don’t use Dexcool
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Fuel Filter
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platinum Plus 4's
1 Distributor Cap and Rotor if 95 and Older
1 Set of Magnacor or STI 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
Wheel Seal and Bearings For All 4 Hubs
2 Swivel grease packs
1 bottle of WaterWetter or Purple Ice
Hoses and belts, as necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Clean/Replace all 4 Wheel Bear sets
Service Your Swivel ***** and Reset Preload
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Change the coolant and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Lube all u-joints
Clean, inspect, repack or replace all 4 wheel bearings
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
Rover144
Aug 15, 2022 03:42 PM
Sarge103
Jan 25, 2013 03:11 PM
Disco Mike
Nov 15, 2012 07:51 PM
Belthasar
May 22, 2011 10:23 AM
