Strange idle issue...
Alright, thought I was at the end of my issues when I replaced the MAF, TPS & Air Temp Sensor, but not so much! Yesterday while on the last leg of a 350 mile trip, I stopped for dinner & when I came out the truck the truck started as usual, but then the idle started fluctuating between 1000 & 250 RPMs erratically. When I stepped on & held the gas at the same place, it would idle evenly but as soon as I would leave off the gas, it would start to idle erratically again; but never stalled. I took a chance & got back on the interstate. For the first mile or so, it acted like it wanted to stall, but never did & then ran fine. Stopped about 50 miles later, and it idled perfectly and I shut the truck off. When I restarted the Disco, the idle went to about 750 RPM, and dropped to about 250 RPM and then went back to a normal idle & ran fine. When I got home last night I turned the Disco off, and restarted it, and the idle went to about 750 RPM & dropped to 250 RPM before evening out. This morning, I started it, and again with the erratic idle. I left it running and checked the fuel pressure at the rail; steady @ 38psi, and watched the TSP reading on my UG which remained steady at 12.2 the entire time while the RPMs but the idle was bouncing between 750 - 250 RPMs. I know I have a dead spot if I step on the gas a bit hard when pulling into traffic from a stop sign that I can overcome if I ease into the pedal, but if the TPS is reading steady, and the fuel pressure is steady, what in the heck is causing this new level of idle Hades??
Nope, I didn't reset the ECM after replacing the IACV. Haven't been near a dealer to do that. Haven't looked at the crank shaft position sensor wiring as I didn't think the issue could be that, but I will.
Not that I'm reaching at straws or anything, but I was just sitting here wondering if there was a plastic safety coating from the shipper on that IACV I might have forgotten to take off... Yep, I'm reaching for straws
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
I did put the gasket on. Curious if Lucky8 can do something like re-flash the ECU. They would be about the closest place I can think of. After all of the weirdness yesterday & this morning, This possessed piece of engineering (in lieu of expletive) started & ran great all afternoon with no issues.
HisRoyalFreshness
11-18-2010 09:01 PM
