Suspension time
Old Jul 14, 2014 | 01:19 PM
HammerFit's Avatar
Default Suspension time
Gonna pull of the wheels this weekend and change the pads. While I was doing that I wanted to change out as many bushings that are worn (most) Where is the best place to order a kit? I see on BA they have a kit A Frame kit, but I dont think thats what Im looking for.
Old Jul 14, 2014 | 01:27 PM
TOM R's Avatar
Mine are orange full set rovers north like $179 full set best price I had found
Old Jul 14, 2014 | 03:12 PM
HammerFit's Avatar
So if I'm looking at this right, considering I have newer shocks so bushings are in good shape. I need trailing arm bushings and panhard bushings for the front?
Old Jul 14, 2014 | 03:24 PM
fishEH's Avatar
And frame and axle radius arm bushings. And A arm bushings if you want.
Old Jul 14, 2014 | 10:16 PM
TOM R's Avatar
Cheaper to buy the kit, and do the rear ball joint while the a arm is off, cheap on amazon iirc
Old Jul 14, 2014 | 10:24 PM
HammerFit's Avatar
Company called FEBEST? $14.95 per
Old Jul 15, 2014 | 08:18 AM
96 rover's Avatar
Rovers north pro line brand is good
Old Jul 15, 2014 | 09:14 AM
HammerFit's Avatar
So bushing kit and leveling ball joint for rear. Anything else I should be looking at replacing?
Old Jul 15, 2014 | 01:52 PM
TOM R's Avatar
Gonna need a shop press, 20 ton +
Have you adjusted swivels and checked tie rod ends, can't recall from your other threads
Old Jul 15, 2014 | 04:46 PM
HammerFit's Avatar
Adjusting swivels is on the list. I saw someone post were they got a 20 ton press from HF. That's also on list. Checking tie rod ends is now on list. What am I looking for? I just as soon as replace them anyways, I want to do as much as possible to get the suspension back to spec.
discoland
Sep 6, 2023 01:42 AM
ljdiscovery
May 15, 2008 09:26 AM
Skibum232
Nov 20, 2007 05:46 PM
larsenken
Sep 7, 2007 08:19 PM
