swivel leak??
Old Jun 1, 2012 | 12:14 AM
AZlandy's Avatar
Default swivel leak??
hello all. so i'm replacing some rotors on a 96 disco and the drivers side went perfect, but when i get to the passenger side and get the hub and rotor off and some grease or something is leaking out . what is it first and how can i fix it ? it leaking on the swivel at the bottom and the front side from the bolts i took one out and decided to stop working on it for the night. please help. and sorry i'm really bad at explaining things lol
Old Jun 1, 2012 | 04:39 AM
See attached, may be #14 leaking, hub seal, separates grease area from swivel liquid.
File Type: pdf
Old Jun 1, 2012 | 09:47 AM
First, how many miles on your truck and when did ou last serive the swivels, reset the pre-load clean/inspect and or replace the bearings and seals? If more the 25,000 mile, you have a bigger project in from of you and should use the Rave CD as a guide to walk you thru doing it. I would also contact Antichrist to get a better seal replacement.
As for the swivel, is the ball itself leaking, have you checked and refilled both of them yet?
Old Jun 1, 2012 | 11:21 AM
antichrist's Avatar
What bolts did you remove? One of #3 in this image? Those are the stub axle retaining bolts.
Was it leaking at the bottom of the stub axle? Or on the back side, at the bottom of the chrome swivel ball?
If the former then you'll probably need a stub axle gasket, or some Right Stuff, if the latter you'll need a new swivel ball seal, and swivel ball to axle housing gasket.
RTC2511 is the hub seal you want.
Old Jun 1, 2012 | 06:33 PM
AZlandy's Avatar
^ yes it was the bolt #3 in the pic. and it was leaking out of the chrome swivel ball as well, so i think its safe to say i need both gaskets . what do i use to replace the fluid that leaked out? and where do i put it back in?
Old Jun 1, 2012 | 06:59 PM
AZlandy's Avatar
i found the swivel housing grease on roverparts.com is there something i can pick up at my local auto parts store ?
Old Jun 1, 2012 | 07:35 PM
Fill your swivels with gear lube, thats what I use.
Or you can use "00" grease from a lawnmower shop, thats what the Land Rover swivel grease is, "00" grease, part gear oil and part grease.
Buy this, Gaiter Kit For Swivel Housings (Part # DA3057) - Land Rover kits from Atlantic British, it is a good kit and will "fix" your leaking swivel seal.
Use RTV where the boot mates to the swivel to make a nice tight seal.
I have this kit on my truck.
Old Jun 1, 2012 | 09:28 PM
antichrist's Avatar
#6 is the swivel seal you need.
swivel.jpg?t=1254831683
I can't remember if the 96 has them, but the drain is circled in red
There's a filler plug about 1/2 way up the swivel housing. It's a 1/2" square.
Old Jun 1, 2012 | 09:29 PM
black sheep's Avatar
This. -I bought the Rover grease but wished I had only paid for "00".
I have seen the gaitier kit on spikes' rig too. I approve.
Good luck
Old Jun 2, 2012 | 12:31 AM
geek_IM's Avatar
here is the fill:
For goodness sakes MAKE SURE YOU CAN GET THE FILL OPEN BEFORE YOU DRAIN IT.
Seems people are a bit sloppy these days with the advice. It pays to be thorough.
Good luck
