Tail Lamp Meltdown
Old Oct 26, 2013 | 10:03 AM
Default Tail Lamp Meltdown
Noticed one brake light way dimmer than the other, almost like it wasn't working. Found melted lamp base. Mine had also damaged the tail lamp housing, so new lamp base can turn too far when latching and contact is lost. Duct tape to the rescue, until a new housing can be obtained from (a) boneyard, (b) Paul Grant, (c) Santa Claus who will pick one up from the elves at the Rovers North outpost.
I noticed that the new in the plastic bag oem Rover lamp base had oxidation on all the contacts, I cleaned that up so they would be shiny. I suppose that these were made about same time as vehicle and have been on a shelf ever since. Probably removing bulb holders, a little crocus cloth, and shine up the connectors in both bulb holder and tail lamp housing, with a little dielectric grease for good measure would be in order. The grease fills up the air pockets between the contacts, so the metal parts still touch, but adjacent areas don't oxidize. If you looked at the contact area with a microscope, it would be like two pieces of sand paper touching, the high points make the contact and there are lots of small gaps.
Attached Thumbnails Tail Lamp Meltdown-p1130668.jpg   Tail Lamp Meltdown-p1130670.jpg   Tail Lamp Meltdown-p1130672.jpg   Tail Lamp Meltdown-p1130671.jpg
Old Oct 26, 2013 | 01:55 PM
CUpgt's Avatar
I kept having a break light go out. Pulled it the other day and the bulb was fine...socket looked like yours but not as burnt. Swapped one from the parts truck and I'm back in business
Old Oct 27, 2013 | 12:30 AM
nuclearw's Avatar
i got some heat damage to the housing north of the bulb... seems like that 2-way gets a lil to hot for its space
Old Oct 27, 2013 | 04:15 AM
saar's Avatar
Won't using led bulbs solve that issue?
Old Oct 27, 2013 | 07:37 AM
Perhaps, if you can get the brightness. The D1 housing is sorta flat, vehicles with curved housings don't do so well as LED light tends to be in a narrow beam. And yep, my housing had "self vented". Might be a place to drill a vent hole, or be sure to use factory bulbs vs something a little different (brighter means more watts, and more heat).
Old Oct 27, 2013 | 09:56 AM
nuclearw's Avatar
i would love to do an LED conversion for my lights, perhaps something to look into.
Problem is the lower wattage draw from LED's will mess with the stock blinkers and you may end up giving people seizures
Old Oct 27, 2013 | 11:25 AM
TOM R's Avatar
I did this on my dodge, you just install a heavy duty flasher to control it
On my d1 I have replaced the city lights, shifter lights and bumper markers with cheap led from ebay
Buzz what part do you need?
Old Oct 28, 2013 | 07:32 PM
Sam95disco's Avatar
I changed watt and it no longer gets too hot.
Greested
LR2
27
May 12, 2023 05:24 PM
jfall
Oct 5, 2013 11:19 AM
Peter Van Slyke
Sep 3, 2013 07:39 AM
DiscoRover007
Aug 26, 2012 10:48 AM
Deutsch100
Aug 4, 2006 11:44 PM
