Telescoping Steering Wheel?
Old Sep 19, 2021 | 12:15 PM
DiscoNewbe's Avatar
Originally Posted by JohnZo
There's a good video out there about troubleshooting the steering. I think it's by Bearmach and involves a mechanic with a helper to rock the steering wheel. That helps pinpoint the problem area(s). Trailfitter's Toolbox Videos, Basic Steering Checks.
The steering box is adjustable to minimize play when pointed straight ahead. How are the hubs? Mine (190k and 175k) required a lot of work (new bearings and pre-load shims for example).
https://www.youtube.com/watch?v=qcKU6-664Pk
Check this out.
That video is awesome!
I had to remove hubs and bearings for a brake job last winter. There was no grit in the bearings, the bearings looked good and spun smoothly, and I regresased after…
Old Sep 23, 2021 | 07:50 AM
JohnZo's Avatar
What about the bearings that the hubs pivot on for steering? Not the wheel bearings.
Old Sep 29, 2021 | 04:24 PM
DiscoNewbe's Avatar
ahhh lol, thank you for that. I guess I don’t know how to check those? I don’t see any marring and it doesn’t seem to be leaking grease.
Old Sep 29, 2021 | 11:26 PM
JohnZo's Avatar
The hub bearings are on the top and bottom of the steering knuckles. The ABS sensors go through the top bearing pin. Check out the diagrams and procedures in the workshop manual. I think I spent a week end or two getting mine set up, not counting ordering and waiting for parts. Probably need a medium level of mechanical ability, but a beginner could follow the manual I suppose. Good videos on the web.
I think it's worth the effort getting in there, based on the messes I found on my high mileage trucks, e.g. busted bearings, worn thrust washers, improper shim thicknesses, etc. I had hopes that would solve my ABS problems, but it did not. There are a bunch of seals that can be renewed while you are there too.
Old Oct 2, 2021 | 10:27 AM
WaltNYC's Avatar
What JohnZo is writing about is generally referred to as a 'swivel ball re-build' When I did mine Trevor at Rovah Parts was extremely helpful and had good pricing.
Old Oct 19, 2021 | 06:10 PM
DiscoNewbe's Avatar
This is definitely an area I’m weak in. I think Bearmach may have some kind of YouTube video, but I’m not sure that this part is actually the issue.
Old Oct 19, 2021 | 10:01 PM
JohnZo's Avatar
Sometimes the best way to learn to swim is to just dive right in.
Old Oct 20, 2021 | 06:47 PM
Mark G's Avatar
I would recommend clamping a vise grips to the shaft of the steering box (not super tight, but 'snug'), then tying the vise grips to the frame, or something rigid, so it won't move at all. then wiggle your steering wheel annd feel if you can feel some 'play'. There could be a joint somewhere in the shafts or between the wheel and steering box which this test will quickly reveal. There could be a slight amount of wear in multiple points that together add up to loose steering. Not uncommon at all. And a little free-play in this region can make the steering feel quite loose.
Also, if all the other suspension and wheel points seem tight perhaps re-look at the steering box a 2nd time. Did you remove the steering box to adjust it? Hopefully you did, most guys don't. About the only way to get a really good 'proper' adjustment is to remove the steering box from the vehicle and adjust in a vise. The reason is, you're adjusting for a certain amt of 'drag' in inch/lbs on the shaft as you move it over 'center'. The normal way to adjust a steering box is to first adjust the bearing pre-load (that's the big nut on the bottom you can't access very well on the vehicle), then adjust the screw on the top. If the pre-load is off and there's up/down movement in the shaft, you can adjust the top screw all you want and it won't remove freeplay. Also, there could be possibly a tiny amt of (wear) on the lower bushing/bearing, that again, if it's got a little looseness in, you'll never adjust that out. The steering box isn't that difficult to rebuild. Once you get the box out of the vehicle and loosen up the adjustments you can check those things.
But maybe you'll find what's causing your steering sloppiness in other suspension points or hubs.
Old Oct 21, 2021 | 12:01 PM
disco96sd's Avatar
D1's don't have telescoping steering wheels - they only adjust vertically
No Doubt
Jul 18, 2019 04:44 AM
eitydeuce
Apr 6, 2018 05:23 PM
hrhoward
Sep 18, 2017 10:55 AM
paupau
Tires
Nov 29, 2012 09:32 AM
plastique999
Mar 12, 2008 04:21 PM
