Telling my rover to stop acting like a self-important b!tch
Old Sep 25, 2018 | 05:10 PM
vanbadri's Avatar
Default Telling my rover to stop acting like a self-important b!tch
Been driving my truck daily since getting it about 8 months ago. Starts right up every time (sometimes a little sluggish when I’ve just cranked recently). Being my daily driver, it barely ever sits for 24 hours. Recently I left it for about two days and went to start it back up and it had a really hard time. Turned over right away, but it sounded like hell for about 10-15 seconds and the oil light stayed on just as long. Not such a big deal but I’ve been rather paranoid lately about oil pressure and my bearings. What’s concerning me is that I’m going to be leaving it for two weeks (probably at an airport) over Christmas, and it won’t be started at all during that time. Has anyone found a way to prime these engines before turning them over?
Old Sep 30, 2018 | 10:56 AM
Crunkgringo's Avatar
I had the light stay on for 10-20 seconds at start up too. It was improved greatly by changing the main and rod bearings. I think we've talked about that in another post. The thing is if your oil light is on then you are getting less than 10lbs of pressure to your sender and the rest of the motor including your top end. I'm guessing this means that your having ticking and knocking until that light goes out and probably quieter ticking after. I assume that's what you mean by it sounds like hell. There is no way to prime the motor before you start it, the pump is drove off the crank. When I rebuilt my motor I prefilled all my oil ways by squirting oil into the rocker arm post oil ways before I installed the rocker arm shafts until the oil filled the oil filter and squirted out the other oil way on the other rocker arm. Even this method didn't fill the rocker arm shafts with oil.
In short the only way your going to fix this is by replacing your main and rod bearings. That will buy you time but the top end is probably wore out too and so a complete rebuild will be necessary eventually. After my rebuild the starter cranking the engine shuts off my oil light and I have 28-30psi at warm idle and 40-42 at 2000 rpm. Like any self important bitch you have to decide to love her or replace her, either way no judgment here.
Old Sep 30, 2018 | 08:17 PM
jimvw57's Avatar
wouldn't hurt to check and see if you are losing fuel pressure when it sits for the 2 days, could be a leaking injector... If it is, your oil may be a bit thin from the fuel draining in the oil. try an oil change...
metzdmichael
Nov 15, 2018 11:44 AM
BBSam
Dec 7, 2016 06:18 PM
aemnky606
Feb 5, 2016 07:09 PM
Extremity
Aug 29, 2013 11:51 AM
shonuff93
May 6, 2013 10:47 AM
