TF relocation cones install questions???
ok, so I just got some rear dislocation cones from terrafrima. they did not come with any instructions. can I get some input from those with these cones.
from what it looks like the round disk should mount on top of the rear coil spring seat, then of course the cone inside the spring and then secured via the bolt to the afformentioned plate? is this correct? I cant see any other way these would mount up.
thanks iin advance
thanks iin advance
Terrafirma Spring Relocation Cones Rear-Pair (Part # TF510) - Land Rover miscellaneous from Atlantic British
AB website product page TF rear dislocation cones.
Purchased because at full articulation in the river bottoms the rear springs dislocate up top.
In the picture you can see the 6-7in disk that looks like it mounts to top of coil spring mount and then cone inside of spring bolted up.
honda50r
Jul 30, 2012 09:39 PM
coil, cones, disco, discovery, dislocation, installing, instructions, land, rear, relocation, rover, spring, terrafirma, top
