Thermostat housing
Old Apr 21, 2012 | 03:27 PM
Trickymonk's Avatar
Default Thermostat housing
Anybody know the torque specs for the two bolts on the thermostat housing? RAVE says 28nm ~ 20.6 ft/lbs unless I'm reading wrong. Working on my 3rd gasket in as many days. 1st one was metal/composite and leaked. 2nd one was paper and split around bolt holes after I torqued. I'm about to try the Felpro from the tech section (it's the last one I have). Is there a trick to this?
Old Apr 21, 2012 | 03:46 PM
A skim of R T V, and firmly twist socket, have never used a torque wrench on mine, will that make it run cooler?
Old Apr 21, 2012 | 04:38 PM
calebbo's Avatar
I didn't torque and I used the paper felpro one (i think it's a chevy engine gasket) and just tightened with a wrench, extension, and socket combo till it was snug. Then I tightened about a quarter turn more.
Old Apr 21, 2012 | 05:37 PM
What he said, tighten evenly, good and snug, then 1/4 turn more.
Old Apr 25, 2012 | 10:10 AM
Trickymonk's Avatar
Just a follow up...I used the Felpro and tightened what I judged to be snug, then 1/4 turn more (still under RAVE torque value). It leaked immediately when I put coolant in (before starting). I continued to tighten until I reached torque spec, then drove the truck. It leaked. I snugged the bolts a little more while warm (1/16 of a turn if that) and now it seems to be holding with no leaks. I've been checking after each trip, but wonder what will happen once summer temps arrive. The next stop will be RTV, but I find it ironic that I can do a successful (so far the truck runs great) head gasket/front cover/timing chain job and cannot get the thermostat gasket or oil sump gasket (another story) to work.
Old Apr 25, 2012 | 10:45 AM
calebbo's Avatar
idk so wait for an answer, but how about RTV plus Felpro gasket combo? And just tighten till it stops. Works everytime for me? haha
rzuluaga
Dec 18, 2015 11:54 AM
ChefGabe
May 21, 2013 06:28 PM
tgarnick
Jan 8, 2013 12:13 AM
Travelor
Jul 8, 2011 09:58 AM
heromanLSU
Nov 4, 2009 12:09 PM
