throttle position sensor screws/bolts
Old Mar 28, 2017 | 10:36 AM
notny41's Avatar
Default throttle position sensor screws/bolts
Anyone know where I can source a couple screws for my TPS? I mangled the heads of mine pretty good when I took them out the other day.
I think they have torx heads and have a superfine thread so not a screw that is easily found at a hardware or parts place i wouldn't think.
Old Mar 28, 2017 | 11:55 AM
OverRover's Avatar
Done that a few times! The bolts are nothing special and if you have a hardware store or a place like Fastenal near you just get a M4x1.0-14 bolt. And to be sure just bring a bolt with you and check the thread pitch/length. I've had a few be 20mm length (it's a Rover ). And the head doesn't need to be torx. Also grab (2) M4 flat washers.
The OE part # is SC104141L (LR calls this a screw) and if you want to order it Go NutZ!> SCREW M4 x 14mm, RNI741, SC104141L - Rovers North - Classic Land Rover Parts
Old Mar 28, 2017 | 12:01 PM
hrhoward's Avatar
I'm going to make a guess based on the torque value required.
4mm with a pitch of 0.7. A good hardware store should have something.
Now granted, I am just guessing without taking mine apart.
Old Mar 28, 2017 | 12:16 PM
notny41's Avatar
ok, I'll bring one in and see if the hardware store has it. Thanks!
Old Mar 29, 2017 | 12:32 AM
notny41's Avatar
Thank you again for the help.
The one on the right I had to dremel slots into the head and use a slotted screwdriver to get it out - that one was tough but not as bad as the other. After getting the first one out, I ended up just removing the head of the second one and sliding the sensor off. Once the sensor was off, I could grab what was left of the screw with a vice grips to get it unscrewed. it was locked in there so tight that I could see the shaft twisting a bit as I was torquing on it with the vice grips.
Ended up getting a couple at Menards. $.59 each.
Made sure to put some anti-sieze on the threads this time.
Attached Thumbnails throttle position sensor screws/bolts-20170328_162911.jpg   throttle position sensor screws/bolts-20170328_162921.jpg   throttle position sensor screws/bolts-20170328_163114.jpg   throttle position sensor screws/bolts-20170328_162844.jpg
Old Jun 11, 2017 | 07:55 AM
caniwi's Avatar
I did the same thing to mine when I removed them. They are tight and the torx doesn't really cut it when trying to loosen them. I went to Fastenal and they had the right ones. Also I put Loctite on them when I replaced them.
Old Jun 11, 2017 | 01:14 PM
ROB99DISCOSD's Avatar
Home Depot sells hex head which I preferred. Fit fine. They're in the pull out drawers.
LRD2&ME
May 13, 2019 09:25 PM
jonhaskell
Dec 11, 2015 08:03 AM
LRD2&ME
Jul 8, 2011 07:16 PM
LRD2&ME
Jul 5, 2011 04:30 PM
rykrover
Mar 2, 2010 06:28 AM
