Power Seat Recline Trouble
Old Jun 5, 2017 | 07:23 PM
99DiscoFlyer's Avatar
Default Power Seat Recline Trouble
Hey fellas,
So my front passenger seat is giving me issues. It works in all axis except it will not recline forward. It reclines backwards fine however.
Any ideas as to whats up? I pulled the control off the center console and it all is hooked up properly.
Old Jun 5, 2017 | 07:49 PM
whiskeynipple0088's Avatar
my problem was solved with just re pluggin the connectors to the controls on the console - perhaps check the fuses -- below the seat you cant see until you remove the plastic under seat cover thingy
good luck
Old Jun 5, 2017 | 08:10 PM
DiscoCam's Avatar
Take apart the switch and clean the metal contacts inside. There is a write up on how to do it: https://forums.lr4x4.com/topic/47674...seat-switches/
Old Jun 6, 2017 | 03:29 PM
Awesome, thanks for that. I'll tackle it this weekend.
Old Jun 6, 2017 | 05:13 PM
dicksoutforharambe's Avatar
I had the same problem. Watched the video on you tube and took it apart, cleaned the contacts. No worries, it only took about an hour.
Old Jun 7, 2017 | 06:48 PM
Do you remember where you found this video? Can't seem to find it on youtube.
Old Jun 7, 2017 | 08:09 PM
Go to google and type in Land Rover discovery 1 seat switch repair. That should put you on the right path
Old Jun 10, 2017 | 10:52 PM
ROB99DISCOSD's Avatar
Ditto.
Old Jun 12, 2017 | 02:05 AM
Never found that video but didn't need it. The linked thread was enough and its all back to normal!
tito5590805
Jun 10, 2021 07:35 PM
fienneone
May 21, 2015 11:22 PM
gbob
Apr 13, 2014 08:22 PM
Townie
Jul 24, 2011 08:03 PM
JBEGIN
Oct 11, 2009 03:06 PM
