Tie Rods..Which ones
Old Feb 21, 2011 | 08:53 PM
thehun's Avatar
Default Tie Rods..Which ones
http://lucky8llc.com/Products.asp?ProductID=4103
http://lucky8llc.com/Products.asp?ProductID=4104
Old Feb 21, 2011 | 09:44 PM
XCELLER8's Avatar
my '98 appears to be the second choice, and it would require a track rod adjusting shaft piece(#NRC4700) which screws ito the rod pictued with only one ball joint.....and then a ball joint which goes into the adjusting shaft
Old Feb 22, 2011 | 08:32 AM
antichrist's Avatar
Do you want the ball joints (tie rod ends) or the drag link and/or track rod assembly?
Those aren't just tie rod ends in your link.
Old Feb 22, 2011 | 08:44 AM
kenk's Avatar
Looks like the only difference is one comes with 3 rod ends(and the whole rod's), the other comes with 4.
Why they would sell one with 3 and one with 4 is odd. If you're gonna replace 3, might as well do all 4.
But like said above, if you want just the rod ends, not complete rods, check out dap or rovahfarm. You can get all 4 ends for well under $100 shipped.
Old Feb 22, 2011 | 08:49 AM
thehun's Avatar
i want all tie rod ends replaced and thought about upgrading the bar as well
Old Feb 22, 2011 | 09:03 AM
jafir's Avatar
Some of these rovers had 4 ball joint rod ends, and some had 3 and one of these:
http://www.roversnorth.com/store/p-4...discovery.aspx
The ball joint is on the pitman arm instead of the rod.
Old Feb 22, 2011 | 12:48 PM
antichrist's Avatar
Ah, ok, nothing wrong with that.
People generally relocate the steering damper (if they keep it) to the drag link to get it up out of the way of damage.
Old Feb 22, 2011 | 02:54 PM
kenk's Avatar
Hmmm, learn something new everyday. I never knew that.
Old Feb 22, 2011 | 08:22 PM
antichrist's Avatar
NAS Defenders have the ball joint on the pitman arm.
NAS Discos have them both on the track rod.
mouse
Nov 18, 2014 05:20 AM
Eaglerover22
Mar 26, 2012 05:04 PM
kgrab
Nov 12, 2010 04:48 PM
malmberg
Nov 5, 2010 12:39 PM
kenk
Oct 7, 2009 07:59 PM
