Time for a new engine
Old Jul 30, 2017 | 04:19 PM
aemnky606's Avatar
Default Time for a new engine
Well that time has come when I have to pull out the old engine and find a new one.
I was driving home from work and next thing you know HUGE cloud of smoke surrounded the truck and she stopped running. I pulled it over and took a look at all the parts laying in the road. Got a tow to the house and pulled out the engine. Had to find out what went wrong as i just rebuilt it. I started with the front cover and found the cause of the explosion. Turns out the thrust plate cracked and the cam walked until it came in contact with the front cover and it came to a stop. As a result of that the timing chain broke and the bottom end went to crap, in the form of piston #1 letting go and punching holes in the block and oil pan.
So now I'm on the hunt for a new motor. Do I have any other options than a GEMS 4.0?
Old Jul 30, 2017 | 05:30 PM
DiscoCam's Avatar
Ouch. That's bad.
You could put in a GEMS 4.6 from a 1995-1998 RR P38. Makes more torque and HP and is pretty much just plug and play. Might need to reprogram the ECU but it's the easiest engine to swap in because it's the same block, heads, mounts etc. Everything is pretty much the same except for the extra displacement.
This is the route I plan on going if my 4.0 takes a dump.
If you just want to put in another 4.0, then this looks like a good option for a rebuild: http://www.ebay.com/itm/Land-Rover-D...JZR-Dl&vxp=mtr
Old Jul 30, 2017 | 08:30 PM
ihscouts's Avatar
Sorry for your loss! That's some pretty spectacular damage for a low rev explosion.....
Normal route instead of finding a 4.6 is to grab a 4.0 and swap in a 4.6 crank and rods, it's easier to find a 4.0 than a 4.6 and it's cheaper. The GEMS ECU does not need an update, both configurations run the same tune.
I'd personally go with an bone yard LS Gen III/IV. If your gonna spend the dime why not?
Old Jul 31, 2017 | 09:33 AM
Mark G's Avatar
That's terrible! Sorry to hear about it.
Old Jul 31, 2017 | 12:23 PM
Paul Grant's Avatar
I've got a nice 4.0L out of a '96 with just 117k on the odometer. It was owned by a friend who is a British car fanatic. He also has an '04 DII, a beautiful TR3, an MGB and a Jensen Healey. If you're interested, let me know.
Old Jul 31, 2017 | 03:17 PM
ihscouts's Avatar
I'll take the TR3 and the Jensen....... can you FEDEX those to 49696?
Old Jul 31, 2017 | 05:20 PM
aemnky606's Avatar
PM sent!
discoland
Sep 6, 2023 01:42 AM
ljdiscovery
May 15, 2008 09:26 AM
Skibum232
Nov 20, 2007 05:46 PM
larsenken
Sep 7, 2007 08:19 PM
