Timing indication pointer
Old Nov 22, 2013 | 03:09 PM
WarriorAce's Avatar
8th Gear
Default Timing indication pointer
First time poster, but long time user of these forums. I have learned tons on this forum and am amazed at the level of knowledge and support you folks offer.
So during the routine maintenance procedure listed, I pulled the rotator arm off the distributor and heard a "clunk" the arm was then floppy. I disassembled the Distributor and sure enough one of the springs had popped off. Easy enough, now however I have to reset the timing on the truck.
I found the timing marks easy enough, they seem to be in better shape than some folks (no cleaning required) however I can't find the pointer! The diagram in the manual is not helpful at all. Am I looking on the bottom of the truck (seem wrong since the marks indicate TDC is on the top of the pulley but I'll be damned if I can figure out how you would see the pulley from the top. Too much stuff in the way.
Truck is a 95 D1 V8.
Thanks!
Old Nov 23, 2013 | 09:44 AM
WarriorAce's Avatar
8th Gear
Anyone?
Old Nov 24, 2013 | 11:36 AM
WarriorAce's Avatar
8th Gear
Figured it out. It's a bit of a peek down though the pulleys to glimpse the pointer. Now of course the Rover won't start to let me check the timing.. Chasing one thing after another.
Elley
Sep 18, 2015 03:09 PM
rodgerste
May 4, 2013 01:13 PM
0304Disco
Dec 9, 2010 12:28 PM
dindra
LR2
Sep 19, 2009 09:21 PM
Phototone
May 6, 2008 07:44 PM
