tire slow leaks
Old Dec 6, 2013 | 06:01 PM
petedisco's Avatar
Default tire slow leaks
Has anyone had any sucess with the slow leaks that plague old alloy wheels I had a set of new tires installed and the fronts leak adding air every couple of weeks? Ie sealers, pressure, i know they can buff the rims but that isnt perfect either thanks.
Old Dec 6, 2013 | 06:19 PM
MarineLandRover's Avatar
I would take it to a tire shop and have them dunk them in the water tank. That will show you exactly where the leak is coming from. That would be the best place to start.
Old Dec 6, 2013 | 07:14 PM
TOM R's Avatar
If there is a lot of corrosion on the bead need to dismount and clean it real good then remount using the sealer goo on the bead, good tire shop should have it, could be the valve stem or valve core, also maybe you ran over a screw right away anything is possible
Old Dec 6, 2013 | 09:20 PM
ajnolin's Avatar
Squirt a little dish soap / water mixture around the bead and stem, look for foaming
Spencerfitch
Sep 27, 2020 12:17 PM
petedisco
Oct 15, 2014 08:08 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
discoboy
Dec 20, 2012 02:24 AM
richukbrb
Nov 29, 2011 07:04 AM
