Tracking down a mystery misfire
Old Dec 31, 2023 | 02:23 AM
  #41
czerta's Avatar
Originally Posted by JohnZo
If valve stem seal is not seated, it will easily lift off. But check compression first, all cylinders with all the plugs out and throttle blocked open, fuel pump disabled.
Understood, thanks.
Compression tester on the way
Old Jan 4, 2024 | 07:12 PM
  #42
disco96sd's Avatar
swap coil and plug to another cylinder - if misfire follows you know your issue
I would put in a new coil - set of plugs and leads
Old Jan 4, 2024 | 08:09 PM
  #43
czerta's Avatar
All coils are new, plugs are a couple hundred mi old at most and same with wires.
Waiting on compression tester.
Old Mar 15, 2026 | 11:05 AM
  #44
augustwillo's Avatar
Curious to what the outcome was from the compression test and if you found a solve for your misfires?
I’m chasing a P0306, P1313 and P1316. Can’t seem to find the issue.
my cyil 7 and 5 are both under 30psi, but still not sure why.
ljdiscovery
LR4
22
Nov 7, 2024 06:06 AM
edognight
Feb 10, 2015 02:01 PM
parke
Aug 26, 2014 09:13 PM
zeblitz
Aug 6, 2014 03:32 AM
tornado_735
Apr 4, 2009 12:39 AM
