trailer harness
Old Jun 7, 2015 | 09:31 PM
TOM R's Avatar
Default trailer harness
picked up a land rover 7 way harness, opened it and looked at the thing, i am guessing i need a land rover brand adapter to goto 4 flat but this thing is unlike any 7 way plug i have seen
Old Jun 8, 2015 | 03:06 AM
antichrist's Avatar
I had one I removed. Didn't like the quality of it. I used the one in this post
https://landroverforums.com/forum/di...34/#post254824
And wired it as described here https://landroverforums.com/forum/di...29/#post179231
Old Jun 8, 2015 | 06:47 AM
TOM R's Avatar
thanks guess is will use the 4 flat i have wired in for now
Old Jun 9, 2015 | 08:20 AM
acamato's Avatar
If its a OEM kit, the 7 way plug is a European plug. Very different form the 7 way US plug. A European 7-Way has separate turn signals and brake lights and a circuit for fog lamps. The tail lights are also separate.
Old Jun 9, 2015 | 08:38 AM
TOM R's Avatar
yup european style, e trailers sells the adapter to 4 flat $20 on sale
http://www.etrailer.com/Wiring/Tow-Ready/118710.html
up in the air weather or not to use this or put a usa 7 way/4way plug on here like the lr3 has
Old Jun 9, 2015 | 01:44 PM
antichrist's Avatar
I see no reason to spend the money on an adapter when you can just cut the wires and wire in a converter, which you're going to need anyway if you're in the US and are not replacing/rewiring your trailer lights.
theswede
Oct 29, 2015 01:05 AM
PedroNole
Jul 2, 2007 07:54 AM
MiniManiac
May 21, 2007 08:55 AM
PedroNole
Jun 28, 2005 12:50 PM
