Trailer Wiring- Please Help
Old Mar 20, 2013 | 10:29 AM
CodyCasteel's Avatar
Default Trailer Wiring- Please Help
I have a 1996 Disco SE7 Im trying to wire up a seven pin connector to. These are the parts I have so far (see picture below)... Where do I connect: the Blue wire(trailer brakes), Purple wire(reverse), Black wire(aux power lead) ? the White is Ground so thats easy... Please help master disco wiring technique guys/gals
And thank you for looking at my thread, even if you can't help.
Again...See below for picture
Old Mar 20, 2013 | 10:44 AM
As you can see in this picture the purple wire is dark and is touching the main plug on the left with a Yellow butt connector.
The Blue stands out as it is light in color and the Black wire is right next to the Blue wire. Both have Yellow butt conectors as well
Old Mar 20, 2013 | 11:50 AM
JPSpen's Avatar
All the leads except brakes are there.. For the brakes you're going to need a brake controller... As far as the others.. Get a little voltmeter at the dollar store and figure out which lead is which.. It only takes a few minutes and you're smarter for having done it...I assume you mean actual trailer brakes and not brake lights..\
Good Luck.
John
Old Mar 20, 2013 | 05:50 PM
@JPSpen.. LOL yeah I meant actual trailer brakes and not brake lights.
And I'm kinda embarrased.. I dont know how to use a volt meter. I never have
And where do I find the two wires i need other than trailer brake? where the plug is behind jumpseat?
Old Mar 21, 2013 | 08:57 AM
antichrist's Avatar
Here's how I did mine.
https://landroverforums.com/forum/di...29/#post179231
Old Mar 21, 2013 | 10:45 AM
JPSpen's Avatar
Wiring for the trailer is underneath the truck.. If not then passenger side rear panel in the corner...
From Antichrist's post:
Black - Ground
Red/Orange - RH Tail
Green/Purple - Stop Lights
Green/White - RH Indicator
Green/Red - LH Indicator
Red/Yellow - Rear Fog
Red/Black - LH Tail
Single Pin Socket A:
Green/Brown - Reversing light
Single Pin Socket B: 20A fuse F6 in Satellite 2 (I think)
Purple/Brown - Power
Old Mar 22, 2013 | 10:12 AM
Thanks everybody ( especially JPSpen ) I can finaly get to work now. Isnt it funny how the smallest things can get in the way of a big project. Thanks again. codabear out
gruehle
Jul 27, 2020 09:10 AM
oliver1071
LR2
67
Jun 26, 2018 11:26 AM
DiscoBenjamin
Jul 5, 2012 07:44 AM
Our1stDisco
Apr 3, 2008 08:50 PM
