Transfer box will not go into gear
Old May 9, 2013 | 08:00 PM
  #31
TOM R's Avatar
universals in front drive shaft, rear drive shaft or slip joints on one of the drive shafts beat, that is what I would check second first be sure all the bolts were tightened during the trans swap could also be a wheel not balanced, mine shakes around 70-75 but I did not dynamic balance the wheels since we did not have the proper weights at my friends shop
Old May 15, 2013 | 08:25 PM
  #32
green-lantern's Avatar
Trying to fix the death wobble it appears the tie rod hooked to the pitman arm has a bunch of play. Are all of them the same? It's a strange design, it goes from pitman arm to left wheel then to right.
Is this the right part?
1994-1995 Land Rover Discovery Pitman Arm - Suspension - Original Equipment 94-95 Discovery Pitman Arm - 273-01014916 - PartsGeek
Old May 15, 2013 | 08:42 PM
  #33
TOM R's Avatar
there are 4 tie rod ends 2 left hand thread and 2 right hand thread
you can get a tie rod end cheaper then that rebuild kit off amazon, I would soak it good for a few days then get it loose and be sure the thread direction or order one of each and do that entire rod
Old May 15, 2013 | 08:51 PM
  #34
TOM R's Avatar
link to my thread on this
https://landroverforums.com/forum/di...od-ends-57946/
Old May 16, 2013 | 01:41 PM
  #35
Thanks a bunch Tom!
GodSavetheQueen
Aug 19, 2013 07:01 AM
atl rover
Nov 10, 2009 03:52 PM
khuds308
Mar 23, 2009 04:27 PM
mdl4usc
Mar 6, 2007 03:27 PM
ant996
Defender
Sep 14, 2006 05:03 AM
