transfer case drain stripped help
Old Mar 1, 2014 | 10:28 AM
TOM R's Avatar
Default transfer case drain stripped help
Well swapped fluids in rears , tc drain was barely snug when removed, went to reinstall and at hand tight it stripped , we cannot get it out, ideas? We tried pull and twist with vise grips no such luck
Old Mar 1, 2014 | 11:04 AM
dusty1's Avatar
that sucks......pull harder while unscrewing..
I have a of lh tap and die set for junk like that. i would put a small bolt in the center to have more twisty pully leverage
Old Mar 1, 2014 | 11:37 AM
fishEH's Avatar
Pull the inspection plate and push at it from the back.
I have the reverse problem in my '96. When my brother still owner it he tightened the drain plug and sheared the head off the bolt. It didn't leak so we left it to fight with it a different day. I'm guessing at some point I'll need to drill it out and replace it.
Old Mar 1, 2014 | 04:34 PM
TOM R's Avatar
Removing cover was a waste of time, there is a giant gear there
Got the copper washer broke off and got under the bolt head wit a panel tool, looks like a screwdriver
Bolt snapped off about 1/4"+ bolt head so we will try to just refill and hope for best for now
Btw the right stuff is a bitch to get off didn't leak though
Old Mar 3, 2014 | 11:32 PM
jfall's Avatar
Put a threader into the drain plug hole - a tap.
try to get the treads back in good order.
Old Mar 4, 2014 | 06:38 AM
fishEH's Avatar
Just going to leave the sheared off bolt in there?
Old Mar 4, 2014 | 07:14 AM
TOM R's Avatar
Yup leaving the sheared bolt for now, plugged the hole with right stuff so far no leaks, 5* this morning and I am still down 1arm so we can only get so much done, spring will be busy I am gonna have to buy a left drill bit to drill this bolt hopping it just comes out
Telling ya never seen a bolt break like this, the end looks machined where is broke
Old Mar 4, 2014 | 11:29 AM
wrongway1's Avatar
Finally something I can help you with!! Back it out with a big easy out & tap the threads for a bigger plug (Autozone has one). I did the same thing (was very careful with the fill plug with all of the warnings on here & not so much with the drain plug and I stripped & forced it into submission), but mine leaked. After the repair, there was no drips.
Old Mar 4, 2014 | 11:50 AM
TOM R's Avatar
Good to know, what size drill and tap did you use? Sucks the bolt cannot be accessed from inside the case
bcolins
Apr 15, 2018 12:09 AM
carlos84
Apr 12, 2017 09:43 AM
Lchop1.8T
Sep 19, 2011 03:00 PM
liPPy
Sep 7, 2011 02:55 PM
audiS4S6
May 6, 2010 06:17 AM
