Transfer Case Drain Plug - Bolt and Thread size?
Old Sep 19, 2011 | 11:18 AM
Lchop1.8T's Avatar
Default Transfer Case Drain Plug - Bolt and Thread size?
Hey guys,
Does anyone happen to know the bolt and thread size of the drain plug for the transfer case or a place to find a direct replacement (AB did not have one)?
Thanks,
Shawn
Old Sep 19, 2011 | 11:22 AM
ValveCoverGasket's Avatar
looked like it was the same as the diff fill/drain plugs - maybe you could pull one of the diff fill plugs and take it to the hardware store.
at least that seemed to be the case on my 5spd truck, i dont know if the auto truck transfer cases were the same or not... but im sure someone else can confirm that.
Old Sep 19, 2011 | 11:41 AM
fishEH's Avatar
I'm almost certain the DRAIN plug is smaller than the FILL plug. I think the FILL plug is the same as the Diff DRAIN/FILL plugs, and that you use a square 1/2" drive breaker bar to remove. The FILL plug is a Hex head bolt IIRC.
Old Sep 19, 2011 | 11:47 AM
ah youre right i may have gotten them mixed up. (did all the fluids a couple weeks ago and it sort of blends together )
Old Sep 19, 2011 | 11:55 AM
Rovers North exploded diagram says it is M8 X 30 mm. Transfer case is under transmissions in the drive train section. It's a hex head bolt, similar to that in the swivels housings.
Old Sep 19, 2011 | 12:20 PM
Lchop1.8T's Avatar
Perfect. Thanks again!
Old Sep 19, 2011 | 12:38 PM
Lchop1.8T's Avatar
Actually, it looks like it is part RND458, according to Rovers North. The other bolt you are refering to is for the cover plate. However, you still pointed me in the right direction to a source that I can order it from, so thank you for that.
Shawn
Old Sep 19, 2011 | 12:53 PM
antichrist's Avatar
If they are out of them post back and I can check the thread and pitch on one so you can get it locally.
Old Sep 19, 2011 | 03:00 PM
Close, but no cigar. I need a new monitor. Sorry.
Grumpo
Oct 22, 2012 12:22 PM
dansgt
Oct 9, 2012 09:04 PM
s10lowrider1994
Feb 25, 2012 07:01 PM
adigerol77
Jul 30, 2011 03:36 PM
theworks001
Oct 1, 2008 10:12 PM
