Transfer Case Front Output Seal....
Old Jan 22, 2012 | 06:57 PM
wheelgarage's Avatar
Default Transfer Case Front Output Seal....
From cleaning the transfer case a month ago, I can now see where the leak is actually coming from. The front output seal is leaking. From looking at job, it looks straight forward.
Has anyone done it yet? Trying to find out what technique was used to remove the seal. The seal puller I have might be too big. I think I need a hook style one....?
Old Feb 21, 2012 | 05:19 PM
TomOwen's Avatar
Same question here. I just developed a leak from the front output seal that is leaking onto the Y-pipe from the exhaust... Hmmm... It is a fairly straight forward weekend warrior job? Remove front shaft (send ut for new u-joints while out...) undo flange, pull seal and place or is there more to it like "look for this type of wear or markings and if so...." or other nuances that would be moverlooked? Thanks as funds are tight and I'm deciding between "yes I can do this" or get it over to local Indy shop. Also, if it is relatively straight-forward, what should this cost to do at an Indy shop?
Thanks in advance, Tom
Old Feb 21, 2012 | 06:51 PM
Danny Lee 97 Disco's Avatar
If funds are tight do not send out for u joints to be replaced, replace them yourself and save.
If it is a small leak, just drain the 80-90 and replace with the heavier 85-140 juice. AND LIVE WITH A LITTLE LEAK.
Old Feb 21, 2012 | 11:39 PM
Still waiting for the complete seal kit...now for almost a month now. Might wait until the transmission is out for a rebuild/replace....
sdhow
Oct 16, 2014 06:31 AM
rfitterer
Jun 3, 2014 11:29 AM
EstorilM
Oct 11, 2011 08:13 PM
ATXDisco
Aug 12, 2011 06:10 AM
ljdiscovery
Feb 15, 2010 10:44 PM
