Transfer Case Shifter rebuild
So, IHScouts made an accurate call. Nice follow-up by WaltNYC with the vid to show you what IHScout was telling you.
Look dude, I actually really do appreciate the fact you took the time to stop by and attempt to help with your first response. But come on man, I obviously didn't know what you meant. "I'll repeat myself..." is some grade A douchbag stuff.
Close... The switch is separate from the linkage; they are not attached. The plunger in the switch is contacted by the diff lock shifter internal component when the shifter is moved between diff lock engaged/not engaged. You can see that in the video in the upper right portion... the plunger is shiny enough to see in the vid.
Gotcha. Thanks man. Hope it's not too difficult to pull apart...
And yeah, I know he was correct.
