Transfer Case Shifter rebuild
Old Jul 26, 2019 | 12:57 PM
Banzai Jimmy's Avatar
Originally Posted by Nick4
Huh, ok. So, the actual switch that the linkage attaches to has a plunger at the end that is probably stuck?
That would be why the linkage easily clicks the top part back and forth without issue?
Thanks dude, guess I'm taking things back apart.
Close... The switch is separate from the linkage; they are not attached. The plunger in the switch is contacted by the diff lock shifter internal component when the shifter is moved between diff lock engaged/not engaged. You can see that in the video in the upper right portion... the plunger is shiny enough to see in the vid.
So, IHScouts made an accurate call. Nice follow-up by WaltNYC with the vid to show you what IHScout was telling you.
Old Jul 26, 2019 | 01:04 PM
ihscouts's Avatar
Super helpful. Glad you stopped by
Simple problem made into a schitball by your dramatics. Hope you’re diff lock bulb burns out.
Old Jul 26, 2019 | 02:39 PM
Nick4's Avatar
Look dude, I actually really do appreciate the fact you took the time to stop by and attempt to help with your first response. But come on man, I obviously didn't know what you meant. "I'll repeat myself..." is some grade A douchbag stuff.
Old Jul 26, 2019 | 02:43 PM
Nick4's Avatar
Gotcha. Thanks man. Hope it's not too difficult to pull apart...
And yeah, I know he was correct.
Old Jul 26, 2019 | 03:11 PM
fishEH's Avatar
Someone needs a juice box and a string cheese.
Old Jul 26, 2019 | 03:30 PM
WaltNYC's Avatar
It is on the end of the thing I outlined in yellow, which is also what ihscouts put in one of his responses.
It's Friday everybody. Go have a beer. Maybe your trucks will run better.
Old Jul 26, 2019 | 03:37 PM
Nick4's Avatar
Seriously, dude!? Come on
Carton of milk and graham crackers, please.
Wtf was kindergarten snack time like at your school?
Old Jul 26, 2019 | 07:53 PM
Nick4's Avatar
Got it. Totally makes sense now. Thanks for taking the time to do that.
Brad S1
Sep 19, 2022 03:25 PM
Timbuktu
Sep 19, 2022 12:49 PM
yoshibond
Jan 10, 2012 12:25 PM
97DISCOIDAHO
Apr 13, 2007 11:09 PM
Acer
Feb 25, 2005 10:29 PM
