Transfer case swap shop time
Old Oct 22, 2020 | 06:31 PM
disco96sd's Avatar
Default Transfer case swap shop time
Anyone know or have a sense what the apx. shop time is to pull out a transfer case in a D1 and install another unit ?
Thanks
Old Oct 22, 2020 | 07:39 PM
WaltNYC's Avatar
The “labor operations time” manual calls for 5.3 hrs on a Defender. Can’t be much different for a D1.
The manual, and many others can be found in the google drive linked in my sig. Help yourself to whatever you need.
Old Oct 29, 2020 | 07:44 PM
disco96sd's Avatar
it appears that the breather hose on top of the transfer case slipped out of the holding bracket - it ended up being on the exhaust and melted shut - forcing the gear oil to spray out thru a gasket and coat the bottom of my Disco - thus no drips or leaks on the drive - and running it dry and causing it to break the bearing and finally seize the gears up - what a mess that was - I was saved by Matt Browne at Overland Engineering in the Portland ME area
disco96sd
Oct 29, 2020 07:41 PM
Duke Duvenstedt
Engine Swaps
Jul 21, 2020 09:03 AM
mutant
Apr 11, 2017 05:16 PM
cornbreadj
Apr 5, 2015 09:20 PM
alex of minnesota
Dec 13, 2006 08:41 PM
