transmission override
Old Jul 8, 2014 | 01:34 PM
screamin demon's Avatar
5th Gear
Default transmission override
can any of you fine fellas tell me where i would find the button to get my 97 disco1 into neutral my wife lost one key an broke the other an its parked in front of the garage an we need to get our camper out today thanks folks
Old Jul 8, 2014 | 04:46 PM
abran's Avatar
I guess there are 2 ways.
I suggest this one:
Remove the steering column shroud(Three screws on bottom) and locate the ignition. At the back of the ignition is a round black connector that fits into the metal ignition barrel. Remove the 2 very small phillips head screws on each side. Pull out connector and use a screwdriver to turn the socket on the black connector to start the truck and move it.
The other way is too complicated for me to explain, and you will still need to push the car.
Good luck.
If you want to call me to walk you through it:
949.413.7396
Old Jul 9, 2014 | 08:42 AM
drowssap's Avatar
put the transfer case in neutral and roll it out of the way
Old Jul 9, 2014 | 09:17 AM
abran's Avatar
^ well that's not complicated at all!!!
So, there is a third and easier than all options way...
Old Jul 9, 2014 | 09:46 AM
drowssap's Avatar
I'm just old and lazy
Old Jul 9, 2014 | 10:56 AM
abran's Avatar
old and wise seem to be synonymous...
alconnelly
Jun 14, 2007 11:20 AM
Tommy Boy
May 8, 2007 10:55 PM
ny1999
Mar 4, 2007 05:46 PM
OzRRS
Mar 29, 2006 11:16 PM
Rob
Oct 6, 2005 11:48 PM
