transmission and transfer case leaks
Old May 13, 2014 | 07:57 AM
TOM R's Avatar
Btw broke a trans mount flipping the assembly on its side so had to buy them also
Also had to patch a hole in the frame under the trans cross bar thing on pass side
Is there a seal on that detent cable I need to do?
Should I bother to drain the converter?
Old May 13, 2014 | 03:19 PM
ihscouts's Avatar
Drill a small hole in converter (don't go deeper than you need to punch the drill through), use a sealing pop rivet to close (make sure it's a short collar rivet). Old trick.
Old May 13, 2014 | 06:27 PM
TOM R's Avatar
No no lol I was just gonna flip it over to drain in a pan , other then cost I always why companies did not all put drains on them, think ford used to?
Old May 19, 2014 | 08:23 AM
TOM R's Avatar
Btw here is the pass side frame under the trans cross member bar thing that we all love, rust through, frame full o silt; , cut out rust spots made a plate migged it in brushed on rusty metal primer, all I can. Say is wow this frame is thin, if d2 is thinner is must be sheet metal
Old May 21, 2014 | 01:04 PM
TOM R's Avatar
Trans bolted up before the rain, problem the trans line on the bottom came off with the adapter, I am assuming there is a copper washer between adapter and trans??
Trans done found the washer/seal, drove all is fine, guess time will tell if I still leak
Old Jan 25, 2023 | 03:56 PM
sandmanspeaking's Avatar
did this solve your problem?
Old Jan 25, 2023 | 10:17 PM
disco96sd's Avatar
"after all this I hope I never have a leak on the trans and case again"
LOL
Spencerfitch
Sep 27, 2020 12:17 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
discoboy
Dec 20, 2012 02:24 AM
ljdiscovery
Jul 15, 2008 08:21 PM
disco12
Mar 6, 2006 05:02 AM
