Trouble Starting
Old May 10, 2011 | 05:51 PM
discoveryjack's Avatar
3rd Gear
Default Trouble Starting
I have a 1997 land rover discovery that I have just replaced the fuel pump. Not the whole assembly just the pump. Now my Rover will start but not until I crank it a couple of times. After a few tries it starts and runs just fine. Help please
Old May 10, 2011 | 06:04 PM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
They just don't build them like they used too. Sounds like an air leak (low pressure in the line). Check for an air leak on the pressure line connection (from pump to engine). Possibly the connection didn't mate all the way, or some debris is allowing air to be vacumed in. End result; hope it isn't the motor. Did you seat the pump motor all the way? If it is not seated correctly, the efficiency will decrease. Why did you replace the motor? What symptoms?
Old May 10, 2011 | 06:05 PM
Chris-bob's Avatar
How is the pressure regulator?
Old May 11, 2011 | 03:00 PM
3rd Gear
I replaced just the pump because it wouldn't start. So i checked the fuel relay (multi relay under hood) and checked the fuel cutoff switch and the fuel pump wiring harness. All had power so i took the pump out and the connectors had been scorched. Where is the fuel pressure regulator located at?
Old May 11, 2011 | 06:07 PM
LRD2&ME's Avatar
The connections on the pump was scorched; as in shorted out? The regulator can be found connected to the fuel injection rail (*top of engine) near the fire fall and under the throttle assembly.
Old May 11, 2011 | 06:17 PM
jafir's Avatar
Probably as in burned and crispy. My D1 pump looked like that. The wires inside the pump assembly that connect to the motor portion were black and crispy and one wasn't connected anymore.
Old May 14, 2011 | 09:43 AM
3rd Gear
it starts right up when the engine is cold. but when its warm it takes awhile.
Old May 14, 2011 | 10:07 AM
LRD2&ME's Avatar
What are the RPM's llike when started cold? Are the RPM's High? What are the RPM's like when started warm? Are the RPM's low? Could possibly be the ECM. I had this same problem. When I changed out the ECM the problem went away.
Old May 14, 2011 | 11:52 AM
Danny Lee 97 Disco's Avatar
Have you read the fuel pressure at the schrader valve on the fuel rail?
Old May 20, 2011 | 03:14 PM
turf63's Avatar
was there ever any resolution to this? I was having intermittent cold starting issues (turns right over when warm every time), and figured "fuel filters never been done, get after that" Change the fuel filter, now my truck has issues starting cold EVERY time. Im getting 28 @ the rail when it's running and when i shut it off, with the key in the on position the pressure drops to like 2 or 3 psi. Does this sound like air in the system to you guys or a pump? More probable that i should go back and check the fuel filter connections, or should i start shopping a pump?
