Trouble Starting
Old May 20, 2011 | 03:37 PM
adigerol77's Avatar
Originally Posted by turf63
was there ever any resolution to this? I was having intermittent cold starting issues (turns right over when warm every time), and figured "fuel filters never been done, get after that" Change the fuel filter, now my truck has issues starting cold EVERY time. Im getting 28 @ the rail when it's running and when i shut it off, with the key in the on position the pressure drops to like 2 or 3 psi. Does this sound like air in the system to you guys or a pump? More probable that i should go back and check the fuel filter connections, or should i start shopping a pump?
Funny, I was just reading in the RAVE about fuel pressure. The line is under pressure when off, reading should be about 2.5psi.
I put gas in this am, always starts right up, first crank, no issues, cold or warm. Drove it 2 miles, turned it off, went to start it up again and it cranked for 2-3 seconds, didn't start. Cranked it again and after about 3 seconds it fired right up. Got it home, turned it off then on again, fired right up. So I'm wondering if I have the beginnings of a delivery issue.
Old May 20, 2011 | 03:47 PM
turf63's Avatar
good. fix that, then tell me what you did and come do it to my truck too
Old May 20, 2011 | 03:50 PM
adigerol77's Avatar
LOL...Yah I don't know if I fixed anything. I'm hoping it was just a little air in the system but something tells me I'm going to be tearing the fuel system apart soon enough. I know I need to change out the filter, I bought it 1 1/2 mos ago and am just getting around to Spikes 60k list.
Does it idle rough during a warm start or just continuously cranking?
Old May 20, 2011 | 04:33 PM
turf63's Avatar
doesnt idle rough at all, except for the initial part where it runs over, it'll start real low like sub 500 and then work its way up, inside like ten seconds. Where as when it's warm. BOOM, satrts right up at like 800 and stays, but whenever it starts after the cold cranking issue it sounds like it's gonna stall until it get its legs underneath it. but only a few seconds. And if you stay in it, and crank it two or three times, its guaranteed to start. just doesnt do it as quickly as papa bear wants it to
Warm starts are a dream. Everything works perfect, only have issues during cold start and it takes a few seconds and fixes itself
no power loss during acceleration, none of the other stuff that would tell me fuel pump.
Old May 20, 2011 | 05:33 PM
adigerol77's Avatar
Is it throwing any codes? Another thought and I'm probably wrong but, could be a bad injector.
Old May 20, 2011 | 07:02 PM
turf63's Avatar
No codes. I had one and it was an o2 sensor. Went away after I replaced em last weekend.
Matt_Attack352
Jan 13, 2014 09:55 AM
socrazy2992
Jul 14, 2012 05:12 AM
hateroffreelander
Aug 23, 2009 11:34 AM
sdsilvere38
Feb 3, 2009 05:35 PM
smt
Mar 1, 2008 11:44 PM
