truck won't start !
Old Jul 20, 2013 | 04:05 AM
buzzliteyeh's Avatar
Exclamation truck won't start !
hi guys I've just bought a 98 disco v8 and the battery went flat , replaced it and the clutch pedal went to the floor and it just turns over , I don't have the original key for the door so can't do the 3 turns thing... I've tested at the coil and it only has 3.9 volts or so ... any advice ? thanks ... oh and I have read through the website ,I pulled out the dash to find no spider unit and I said the "fix' to the green box , all that did was stop it for turning over and made the horn go off ....
thanks
Old Jul 20, 2013 | 07:52 AM
TOM R's Avatar
there is no code in the door key you just need one to fit the lock, do you have a remote? I have not had this problem YET but I am sure it will rear it's ugly head soon after I fix the high idle
Old Jul 20, 2013 | 10:59 AM
hi thanks for the reply , yes I have a remote and it works fine , I'm thinking I might take off the door panel and try to activate the code that way , if that doesn't work I think I might try a new coil
Old Jul 20, 2013 | 08:24 PM
ummm.. back to basics -
Got spark? The ECU grounds the coils to make it, but that signal is derived from the crank position sensor (CKP). Bad sensor = no spark.
Got fuel pressure? Test valve on passenger side fuel rail, like a tire valve. Pump runs for like 2 seconds when key turned to position 2. Expect 32-34PSI when running.
Red alarm light on dash should not be on or blinking.
Old Jul 20, 2013 | 09:29 PM
TOM R's Avatar
When I swapped my batt today the red light on dash was solid turned key and nothing,shut the doors and hit the lock button on remote a few times till doors locked then hit unlock and light went out and it started
Old Jul 21, 2013 | 06:36 AM
Thanks guys, the truck runs on gas at the mo and has gas pressure at the engine bay , I check the restance on the coil today and instead of 13 ohms it has 8ish on the main coil so I think this maybe the problem so I'm going to order a new coil and see how it goes
Old Jul 21, 2013 | 06:43 AM
Isn't it a series of 4 coils (two cylinders each) - long thing at back of engine on a 98? Instead of distributor and single coil as in earlier models? Here's the Eagle eye view of my 97's.
Old Jul 21, 2013 | 07:19 AM
DiscoJag's Avatar
Yes, my '96 has the coil pack at the back of the engine. (?)
Old Jul 22, 2013 | 04:43 AM
Nope I just have the one coil next to the radiator on the passenger side ,it goes to a distributor , it should arrive in a few days , I live in Humty Doo , out from Darwin . I hope it fixes it !
Old Jul 22, 2013 | 04:46 AM
If it doesn't ill check the crank position thing
Thanks guys
Skyelr3
Jan 29, 2017 08:02 PM
Carolina919
Nov 30, 2014 08:36 AM
toad2
Jan 17, 2014 09:19 PM
robersonb
Feb 25, 2013 05:19 PM
DiscoRover007
Aug 22, 2012 06:20 AM
