Turn signal click noise
Old Apr 30, 2011 | 11:55 PM
Harris97's Avatar
8th Gear
Default Turn signal click noise
When my 97 disco is running the turn signal noise clicks non stop quite rapidly. when i turn on left or right signal it slows the clicks down this has been an annoyance for a while ive searched the forums could find anything any ideas?
Old May 1, 2011 | 08:47 AM
Long Haul's Avatar
You have a bad bulb on the right side if it is flashing rapidly on the right and normal to the left. Turn the hazard lights on and walk around and see witch ones flash on the left side but not the right.
Old May 1, 2011 | 10:07 AM
vegas99d1's Avatar
Brian hit it right on the nose. The faster blinking is caused by less resistance in the blinker circuit...usually a blown bulb...but..my disco does this on occasion...what i had to do was put dielectric grease on each bulbs contacts in my taillights, bumper lights and front turn signals. This solved the issue when i couldn't find any bulbs that were blown.
Old May 1, 2011 | 01:59 PM
The bulbs in the rear bumper wiggle loose on my truck all the time, drive to work and they work normal, hit a bump half way there and they blink fast.
Reach under the bumper and wiggle the bulb and all is well once again.
Old May 1, 2011 | 05:20 PM
tweakrover's Avatar
That's not what he is saying. He said it clicks all the time, but it slows to normal when he uses the signals
Old May 1, 2011 | 05:37 PM
ShadowMerchantBC's Avatar
I just replacemed my pannsger side blinker bulb and mine still blinks faster, but thats only when I turn on my right directional.
Old May 1, 2011 | 06:00 PM
vegas99d1's Avatar
Sorry, completely misread the OP...i would think it is a malfunctioning blinker switch...not complicated to replace at all.
Old Feb 9, 2013 | 01:55 PM
Adam78's Avatar
I know this is an old thread, but was this ever resolved? I'm having the same issue. fast blinker noise which returns to normal when signals are used and stop completely when the lights are on lol
Old Feb 9, 2013 | 06:23 PM
Replace the relay.
I had the same thing happen this last summer, traced it to a relay under the dash.
It went away before I could replace it, not worried about it until it happens again.
toad2
Jul 31, 2010 07:17 PM
hilltoppersx
Jul 28, 2009 04:36 PM
girouardrover
Jul 16, 2008 04:55 PM
hsmatharu
Defender
Aug 23, 2006 12:33 AM
