Upstream (front) O2 sensor electrical connector access?
Old Apr 4, 2013 | 06:41 PM
archaeology_student's Avatar
Question Upstream (front) O2 sensor electrical connector access?
Hi everyone,
I replaced my downstream (rear) O2 sensors about a week ago, and just received my new upstream O2 sensors this week (all NTK/NGK 25044).
I am having difficulty accessing the electrical connectors as there is barely any room for my hands. I traced the wires from the sensors themselves and they come up behind my engine on top of the transmission bell housing, and seem to be stuck on there. I know how to unclip the connectors but I do not have the room.
I can see the drivers side easily enough, but can not even see where the passenger connector is.
Are there any tips or tricks for obtaining access? Should I disconnect the ignition coil just to make room and access?
Cheers and thank you
Old Apr 4, 2013 | 07:09 PM
Scope's Avatar
That about sums it up.Some have done it without removing the coil pack but I needed the
extra room.
Old Apr 4, 2013 | 07:21 PM
keoni004's Avatar
Any chance you could use an angled pick to undo the connector? I'm about to do the same, so interested in your progress. I'd like to do it without pulling the coil pack.
Old Apr 4, 2013 | 09:25 PM
My advise is to pay to have it done.
You need to remove the coil pack, and have small hands.
Old Apr 4, 2013 | 09:53 PM
TOM R's Avatar
i did it without removing the coils but it was near impossible and cut my hands all up, the coils remove easy enough( didn;t know it at the time) would definitly make it easier
Old Apr 4, 2013 | 10:40 PM
fishEH's Avatar
Pull the coil pack. Four little bolts and one plug and its out. Easy peasy.
Tie your hood off to a roof rail to get it to open farther for better access.
Old Apr 4, 2013 | 10:46 PM
Wink
Maybe for the driver's side, but not for the passenger side. Will keep peeps updated once done... thank goodness the weekend is almost here
Old Apr 4, 2013 | 10:47 PM
Wink
If I can do it myself I would like to, and I get to learn more about vehicle
Old Apr 5, 2013 | 08:41 PM
You must remove the coil packs, 4 nuts hold it on, it sets on studs.
Some even lower the whole engine/trans by loosening the trans motor mounts.
I did not do that, I just removed the coils, still a PIA though.
Old Apr 5, 2013 | 09:32 PM
pinkytoe69's Avatar
It can be done without removing the coils, but it sucks.
Not removing them means the passenger one may require snaking your hand up around the transmission from underneath.
