Upstream O2 sensor replacement
Old May 28, 2013 | 04:56 PM
Smith CH's Avatar
Default Upstream O2 sensor replacement
I recently got a O2 sensor fault in bank 1 sensor 1. the truck was recently in a collision so I want to unplug it and reconnect before I replace it just to make sure its not a bad connection. ATM i cant tell if its mixing rich or lean, I thing since its just the one the mix is the same, but I cant find where its connected. the wire runs up over the bell housing it looks like and I cant seem to find it. Anyone done a replacement, or know about where the connecter is? its the driver side upstream sensor
Old May 28, 2013 | 05:59 PM
Scope's Avatar
It is at the top of the bell housing behind the coil pack.Very tricky to get to.
Old May 28, 2013 | 06:35 PM
TOM R's Avatar
thread on it https://landroverforums.com/forum/di...nectors-59342/
basically remove the 4 nuts holding the coils down and unplug them then remove from engine and that will give you room to access
csp
Jul 18, 2013 05:18 PM
archaeology_student
Apr 14, 2013 01:51 AM
aeroschmitz
Mar 21, 2013 11:07 AM
javasteve
Feb 24, 2013 09:36 AM
Discolife
Dec 3, 2011 09:49 AM
