vibration in steering
Old Jul 10, 2015 | 11:08 AM
Shiftonthefly1's Avatar
I doubt it's those. They don't hold a load really. Weight is all on the wheel bearings. They are more of a guide.
Old Jul 10, 2015 | 09:12 PM
antichrist's Avatar
I doubt it's them either, but they are moving parts.
Have you pulled the front propshaft to see if the vibration goes away?
Old Jul 10, 2015 | 10:50 PM
TOM R's Avatar
No but the drive shaft was not vibrating running on the lift
After my long drive it only vibrates bad under accel 30-40 MPH
If I hold around 35 it is constant and does not go away
It feels like I am driving on those rumble strips on the side of the road sounds like it too
But only at that speed, was not this bad with the vibration damper on there
Think I might need to address the angle of that front rear, maybe go to a d2 front shaft
Old Jul 11, 2015 | 06:03 AM
antichrist's Avatar
Yeah, but running it on the lift can only go so far towards mimicking on the road. Plus it's something that is easy to rule out. Probably the easiest, certainly the cheapest.
Old Jul 11, 2015 | 08:04 AM
Yea on a lift suspension is at all different angles because it has no load. My money is on that diff angle/ front shaft.
Old Jul 11, 2015 | 09:05 PM
TOM R's Avatar
We had it lifted by the axles so full load on suspension
My front pinion angle is so much it points directly at the xfer case
Old Jul 11, 2015 | 11:14 PM
antichrist's Avatar
Driveline Geometry 101
Old Jul 12, 2015 | 08:12 AM
TOM R's Avatar
OK by that site my pinion angle is fine if I had a d2 front shaft, but my caster is off quite a bit
So do I change my drive shaft style or fix my pinion angle or both? This is my dd so it needs to drive right
Old Jul 12, 2015 | 09:40 AM
fishEH's Avatar
Start by pulling the frint shaft amd see if the vibration goes away.
Old Jan 21, 2016 | 06:04 AM
TOM R's Avatar
Update, I did reseat the front wheel bearings they were a little loose, no change, I have a d2 front drive shaft to try just need the tc flange
