vibration in steering
Old Jan 21, 2016 | 09:40 AM
  #21
binvanna's Avatar
If the panhard rod or radius arm bushings are bad, the whole front axle will shake. The panhard rod has the smallest bushings given the load it bears holding the axle from lateral movement.
Old Jan 21, 2016 | 10:00 AM
  #22
MM3846's Avatar
Driveshaft vibes give you a nice harmonic low tone at highway speed, like someone has a subwoofer blowing a 40hz tone under your truck. I bet its the driveshafts.
Old Jan 22, 2016 | 09:33 PM
  #23
TOM R's Avatar
Bushings are all urethane, pan yards adjustable, wheels were rotated and rebalanced , the vibration is felt on the tie rods and transferred to the steering , I believe its coming from one or both knuckles but guess time will tell what's causing it
Old Aug 17, 2016 | 12:35 PM
  #24
TOM R's Avatar
So resurecting this, break in the weather I finally pulled the front drive shaft and now the vibrations gone, truck seems to drive way smoother acceleration is smoother so no idea if the drive shaft was the issue or just part of it
There was no play in the u joints since I had replaced them, just a little in the slip but not enough to cause concern
Swapped in the d2 flange just need new nuts for the d2 shaft, guess well see if the vibration returns
Old Aug 17, 2016 | 03:08 PM
  #25
ihscouts's Avatar
I was thinking of doing the same, angle and short shaft.
Old Aug 19, 2016 | 11:18 AM
  #26
TOM R's Avatar
D2 Drive shaft is in and still no vibration so the d1 shaft was the problem, this is strange since we ran it on the lift weight on suspension and it looked fine, oh well on to the next issue lol
I will say there is not much in travel on this shaft with 2" lift only like 1" or so sticking out of the slip, but looks about the same as my rear shaft
Old Aug 19, 2016 | 03:05 PM
  #27
hrhoward's Avatar
What are the advantages of the D2 front shaft? Are there any for a stock truck?
Old Aug 19, 2016 | 07:13 PM
  #28
TOM R's Avatar
D2 has a double joint at the transfer case , helps with lifted trucks, no idea if it would fit or work on unlifted d1
Old Aug 19, 2016 | 07:40 PM
  #29
fishEH's Avatar
No need for a D2/DC shaft on a stock D1.
Some lifted D1's do fine with a stock shaft, others don't.
Old Aug 22, 2016 | 11:43 AM
  #30
hrhoward's Avatar
Tom, fish,
Thanks for the info.
notaguru2
Feb 22, 2009 05:33 PM
luxury1
Jan 18, 2009 07:46 PM
khandrh
Apr 18, 2008 06:30 PM
zerochills
May 4, 2007 02:29 PM
anthonyb
Aug 16, 2006 11:09 AM
