VSS causing hesitation
Old Jun 6, 2013 | 11:12 PM
jbriggs's Avatar
Default VSS causing hesitation
My Disco has had a hesitation problem for quite some time. When I would drive on the highway about 60 to 70 MPH it would hesitate or the engine would reduce power which I think it is supposed to do when the computer detects and overspeed. Anyway it only did it once in a while so I lived with it until one day I was driving and when it did it the speedometer dropped to zero. It only lasted a couple seconds but I figured was time to deal with it. I read that you can rebuild thembut the sucess rate isn't that high so I decided to drop the coin on a new one. I bought it from Rovah Farms, Trevor was great to deal with, at $96. When I took the old one out I was glad I bought the replacement. It fell apart and had a lot of corrosion inside the housing. I believe if I had rebult it it wouldn't have lasted. So it runs fine now with no hesitating for about a month. Hope this helps anyone else having the same problem.
JB
Attached Thumbnails VSS causing hesitation-img_0493.jpg   VSS causing hesitation-img_0494.jpg
Old Jun 7, 2013 | 08:35 AM
gprtech's Avatar
That's not corrosion, it's grease mixed with shavings from the nylon bushings.
If you replace the bushing with a ball bearing, it'll never wear out.
However, the sensor uses a reed switch. If you get instances where the speedo drops to zero, it's probably the reed switch.
scottmb23
May 31, 2013 02:38 PM
br0keit
Mar 6, 2013 07:56 AM
vandal996
Feb 17, 2011 09:44 AM
spjcarter
Nov 21, 2010 03:51 PM
rebooTT
Jun 20, 2005 01:09 AM
