War on Misfires
Old Jun 15, 2015 | 11:15 AM
  #181
TOM R's Avatar
what sensors have you tried?
i rebuilt the engine, installed yellow volvo injectors, plugs, wires, fuel pressure regulator, reset adaptive values, swapped ecm, reset values new ecm, went back to old ecm reset values, replaced fuel pump/strainer/fuel filter, fuel temp sensor, cleaned maf, swapped maf probly other stuff all no change codes actualy are getting worse since rebuild
also swapped coil packs, when i rev the engine even 1 time it pops as rpms are coming down so theres definitly a miss
i was rid of the 1179 now its back along with the 1313 , 1314 so wtf
i have not tried crank or cam sensors and my mil light does not work even prompting it with the scan tool guessing bulb is out, whats the mil light look like ? guess i should say nothing extra lights on dash when i prompt mil
Old Jun 15, 2015 | 11:26 AM
  #182
USNAVYORDNANCE's Avatar
I will count my lucky stars. I don't have any issues with my rebuild/stroke. Knock on wood... Tom, maybe the injectors aren't agreeing with the system?
Old Jun 15, 2015 | 01:51 PM
  #183
TOM R's Avatar
had the issue before i swapped injectors, infact it would not run then till i did fuel pressure regulator iirc so did injectors same time i believe
Old Jun 15, 2015 | 01:53 PM
  #184
EricTyrrell's Avatar
Since the codes started I've replaced the coil packs, plugs, wires, ECU, TPS, CTS, IATS, CkPS, IACV, FPR, injectors, repaired a bad coil pack connector, and inspected reluctor ring for correct gap. Have not replaced cam position sensor due to their insane cost.
Old Jun 15, 2015 | 03:06 PM
  #185
TOM R's Avatar
WONDER if it would be worth trying a used cam sensor , not sure exactly what it does since there is a crank sensor
if the cam sensor has something to do with timing then could be the issue
oh yeah and add the ael fuel sending unit to my list, i feel like i have replaced the entire truck at this point
maybe i am not getting enough fuel from the autozone replacement pump?
there is probly some guy in uk drinkin a pint laughing at us as he reads this saying dumb yanks its right there staring them in the face
Old Jun 15, 2015 | 10:57 PM
  #186
Ah yes, I've tried three different fuel pump types including OEM. No dice. I'd gladly test a volunteer cam sensor.
Old Jun 16, 2015 | 07:03 PM
  #187
philwarner's Avatar
Default P1313 & p1314
I haven't replaced nearly as much as you guys have, just plugs and wires and fluids, so today I ordered two new “NGK 25044 Oxygen Sensors” from Amazon.com for $97.16 total. The Listing says: "OE MFR: NTK, DIRECT FIT OXYGEN SENSOR, w/AELS (ADVANCED EVAPORATIVE LOSS SYSTEM) This product fits these positions on your 1998 Land Rover Discovery: Downstream Left, Downstream Right, Upstream Left, Upstream Right."
I just have to get the old ones out now and clean them up and have spares for the downstream; I figure the upstream are the most important for better MPG and I'll see if swapping the downstream around affects the P1313 and P1314. I soaked the downstream sensors in Berryman Chem-Dip carb & parts cleaner in an old asprin bottle; maybe there was some asprin dust left that will cure their headaches.
I had tried to remove the crank position sensor to check it, but mine is not at all like what is described in the RAVE and while the cover feels loose on one side it just didn't want to come off and I couldn't find any bolts under all the nasty oil and dirt. That will be my next attempt if new upstream O2 sensors don't help.
Old Jun 16, 2015 | 07:23 PM
  #188
TOM R's Avatar
Yeah o2 did not help , bought same ntk from amazon, think mine is better since I just reset values but sure it will return
Old Jun 16, 2015 | 08:52 PM
  #189
I've got a cam sensor on the way. Will report back.
Old Jun 17, 2015 | 12:32 PM
  #190
TOM R's Avatar
Iirc when I was a GM dealer tech many moons ago the tech 2 scanner could show pulse width on injectors and coils to diagnose the problem, any such scanner for rover
Since my code was for cyl 6 I guess that's where the problem lies , would be nice to know if its the injector cutting out or the coil
