Water sound under my dashboard?
Old Dec 31, 2010 | 05:42 PM
pimnmike's Avatar
Default Water sound under my dashboard?
I have this water flowing sound when I am turning the steering wheel. It only happens when the car is moving? I think it may be condensation in the lines, but I really don't have a slight clue. Does anybody know what it could possibly be?
Old Dec 31, 2010 | 05:56 PM
hilltoppersx's Avatar
You have air in the coolant system. You need to bleed the system properly. Directions are in the how to section
Old Dec 31, 2010 | 07:51 PM
pimnmike's Avatar
Thanks hilltoppersx, I'll go and do it.
Old Jan 1, 2011 | 10:25 AM
Before you do that and since the sound only happens when turning, clean out your a/c drain lines.
Old Jan 1, 2011 | 11:19 AM
pimnmike's Avatar
Is that something I can do or do I have to take it to a shop?
Old Jan 1, 2011 | 04:44 PM
Any of us can walk you thru that.
Old Feb 6, 2020 | 03:59 PM
DiscoNewbe's Avatar
Default Follow Up
Hey, just wanted to follow-up and see if bleeding the air solved the problem?
I have the same problem in a 1999 Discovery SD. No problems with overheating at all and no white smoke coming out of my exhaust, but I do have that waterfall sound and am worried how it got there it the first place?
eitydeuce
Dec 25, 2013 09:34 PM
rod76
Feb 25, 2010 02:10 PM
Roveroh
Sep 19, 2008 06:40 PM
lennie5936
May 28, 2008 07:54 AM
arteliare
Mar 27, 2008 10:45 AM
