Water Sound on the dashboard....
Old Mar 26, 2008 | 11:23 PM
arteliare's Avatar
7th Gear
Default Water Sound on the dashboard....
I have a '97 Disco....there is a sound similar like pouring water....I hear the sound at the dashboard on the passenger side or in the middle part of the dashboard....what do you thing this is?....will this be an indication of a larger problem?.....
The sound happens randomly but is frequent....the water temperature gage of the truck does not go over 1/4....
Please help!!!!
Old Mar 27, 2008 | 01:20 AM
Sfef84's Avatar
Default RE: Water Sound on the dashboard....
I have an 03 DII and I get that same noise! Its like a glurking sound or a bottle with water slushing around. I have no idea what it is... maybe low on some sort of fluid?
Old Mar 27, 2008 | 02:54 AM
JakeBrown's Avatar
My 95 Disco does it too, I just got mine out of the shop for a diagnostic and they told me it was a bubble in the coolant system. I've asked the question before, and it seems that it can be an indicator of a larger problem though too.
Old Mar 27, 2008 | 04:13 AM
aBs0lut30's Avatar
My 01 Disco 2 does it, but only every once in a while. Mostly when its cold. That said, have never had any problems with it. I had kinda always figured its something in the heater core....
Old Mar 27, 2008 | 08:47 AM
okdiscoguy's Avatar
How many miles? Thermostat might be stuck open to read so low, but the sound is air trapped in your coolant system. With the endine coll, and parked on an incline, open the little plastic screw on the radiator. If you have coolant all the way to the top, you should be ok. Do a search for radiator bleeding on here and see the full process...
Old Mar 27, 2008 | 09:39 AM
So, you all have coolant leaks and should fill you coolant system, bleed as much air thru the bleed screw then go have your coolant system pressure tested to find and then correct your leak.
Old Mar 27, 2008 | 10:45 AM
NWDiscoRover2004's Avatar
Sun Roof drain? Last time I was up skiing it snowed over a foot. All the snow on the roof started melting on the drive down the pass and it sounded like a waterfall in the cab of my '04 Disco. It turned out to be the sun roof drains doing their thing.
I checked for wet carpets when I got home as I've had history with clogged drains and it was dry as a bone.
Just a thought on your water sounds.
Cheers,
Curt
pimnmike
Feb 6, 2020 03:59 PM
eitydeuce
Dec 25, 2013 09:34 PM
mvjimenez
Jun 12, 2010 10:25 AM
rod76
Feb 25, 2010 02:10 PM
Roveroh
Sep 19, 2008 06:40 PM
