Well, it was too good to be true
Old Jan 16, 2014 | 10:59 AM
dipdgarage's Avatar
Default Well, it was too good to be true
My 96 was doing farely well until this morning while driving to the city. I was on the freeway and all of a sudden hear a pop come from front area. Seemed like my front right tire had blown. I exit and look at the wheel/tire no problems. check the rest no problems. Kept driving nice and slow (30 mph) with hazards on and then vibrations began to get worst and finally heard a really loud collection of bangs come from front almost like i lost parts of the truck. I pull over and no leaking fluid, nothing is hanging down, loose or broken. After that loud bang the shaking went away (kept driving at around 25-30) but when i turn the wheels a little bit of noise kept coming from front right. I got home and parked it. I don't know if its the front diff that may have just destroyed itself or maybe the axle/hub? Any input?
Old Jan 16, 2014 | 11:01 AM
CUpgt's Avatar
sounds like a CV joint. Jack up the truck and unbolt the drive shaft from the diff. Turn the wheels and listen for noises and check for resistance. Diffs are cheap as well as front axles. I have some front axles I really don't need sitting around if you end up needing one.
Old Jan 21, 2014 | 04:20 PM
dipdgarage's Avatar
Well, I took the wheel off and spun it. I started to think okay Ill hear that axle beat up and then realized the drivetrain piece from Center diff to front diff was making a noise and was wiggling. Look under and see that where it meets the center diff it cracked. Here are some shots.
Here is a video that may help see it better.
Any good hints to where I can find one for a good price? Do only D1 fit or does it share with others?
Old Jan 21, 2014 | 05:44 PM
kingsly's Avatar
I've never seen a broke propshaft before! Check the center and front diffs, make sure nothing is binding up that would have overloaded that shaft and broken it. It shouldn't just fail unprovoked like that...
Old Jan 21, 2014 | 06:25 PM
dipdgarage's Avatar
Its weird, all i can recall was my diff lock was stuck and never had a problem. But, I never disengaged it since the system was stuck. I dunno if that influenced it with the drive...? I had put many miles since though. We shall see. Ill take the front shaft off so atleast i can drive just RWD lol.
Old Jan 21, 2014 | 06:57 PM
fishEH's Avatar
Look no further, your CDL being constantly engaged caused your driveshaft to fail.
1) Get a new driveshaft
2) Unlock your CDL.
Old Jan 21, 2014 | 07:00 PM
calebbo's Avatar
Short and sweet!
Old Jan 21, 2014 | 07:11 PM
dipdgarage's Avatar
Im going to have to look at how to unlock it manually lol (feel like such a noob!!!! been doing imports forever but not 4x4 beasts like this!!) Thanks for all the patience guys. If anyone can throw me in a direction for adjusting my diff itd be greatfully great!
Old Jan 21, 2014 | 07:25 PM
If the shaft is broken (I can't see pix on my phone) you may have to keep CDL engaged. It is a common work around with a busted shaft to pull it out and drive with CDL on until repairs can be funded. You have a 2WD Rover. CDLs if not exercised can freeze up. I was able to squirt a half a can of PB BLaster down in mine by taking loose some of the shift boots and working the nozzle down beside everything.
Old Jan 21, 2014 | 07:31 PM
dipdgarage's Avatar
Yes, the diff will stay locked while i replace the shaft.
When i move my shifter boot it moves but it feels like nothing goes on. When I got it I didnt have diff lock on and then I messed with it some and locked the diff Luckily it was prior to offroading and it works like a champ lol
