At what speed does your disco change to 4th gear?
Old May 7, 2013 | 08:59 AM
Sam95disco's Avatar
Default At what speed does your disco change to 4th gear?
Auto tran discos only.
Mine seems to do it after 50mph.
Just like to know what other discos do, if yall don't mind posting your results.
Last ?, is there a way to adjust the the tranny to change gear before 50?
Old May 7, 2013 | 11:32 AM
Just about 52-53 mph. Will hold it down in the 45 area. Shifts are contolled by pressure. Tranny fluid, any additive, tire size, engine, wear, all these things add in there. Tranny guy might be able to swap out an internal valve.
Old May 7, 2013 | 11:57 AM
Sam95disco's Avatar
You think by adjusting the kickdown cable so it would change at a lower speed, say 40? Would that damage the tran?
Old May 7, 2013 | 12:40 PM
tooltech's Avatar
Mine shifts right at where Buzz mentioned... and will hold it until I go uphill and/or drop below ~49mph...
Old May 7, 2013 | 12:54 PM
bcbp's Avatar
Same here 52-53.
Old May 7, 2013 | 02:19 PM
pinkytoe69's Avatar
I have 31" tires and also upshift at about 53.
Old May 7, 2013 | 02:35 PM
georgep's Avatar
Since mine is now FIXED and running. Normal throttle about 50 mph Foor to the floor about 58 mph.
Old May 7, 2013 | 04:03 PM
TOM R's Avatar
same hear 50 ish
Lord Wert
Jul 10, 2020 02:50 AM
norcalcasey
Oct 28, 2014 05:48 PM
Dane!
Feb 24, 2014 05:41 PM
hhalimi
Apr 19, 2012 07:51 PM
